Tractor Talk Discussion Forum
O/T New Project......Boat Motor
john in la
09-03-2007 07:38:55
Ok I know it is not a tractor but everyone needs a little R&R every now and then.
Picked up this 1972 Sears; Ted Williams outboard; with a Tecumseh 7.5 hp 2 cycle motor.
third party image
Larger picture
Does not run well and hard to start. Seems it is flooding out. Figured I would take a chance on it. Took the carb off and found that someone has had it off in the past because I could not find part #6 which is labled ELEMENT, PUMP in the parts diagram.
third party image
So a carb rebuild is in order to start with. The question I have is... There is a part mounted between the carb and the engine block called a REED and a STOP REED. These parts are showing as NLA.
What function does this reed do.
Really want to do what ever it takes to get this running right but on the other hand do not want to take apart parts I may not be able to get anymore.
Thanks
John
JCSinGA
09-03-2007 16:06:03
 Re: O/T New Project......Boat Motor in reply to john in la, 09-03-2007 07:38:55
I've have heard "the two happiest days in a boat owners life is the day he buys the boat and the day he sells the boat". But I still like to tinker with an old outboard from time to time myself. Good luck on your purchase.
1936
09-03-2007 15:38:28
Make your first trip up river and have some orrs along. Lets the site know on your test run?
Steve A W
09-03-2007 09:26:41
For a lot of info go to www,marineengine,com They have a very active discussion forum. I have more than a few old boat motors and have gotten a lot of info from there. Good luck, and enjoy boat motors. But BEWARE they multiply!
37 chief
09-03-2007 09:04:13
I think you could find a lawn mower engine with the same carb. The Indian Motorcycle co. made outboard boat motors back in the 30's. Anyway this project will keep you bust for a while, have fun. stan
bo
09-03-2007 07:47:34
Throw it away. Having said that, the Sears, Eskas and others were price motors, noisey and mostly unreliable. If you want a project motor, get a Evin/Johnson or Merc. Parts will be availble and they were much better motors.
Reeds..... a two cycle engine uses the whole engine block cavity as a "pump". It draws gas through the carb, through the reeds and into the combustion chamber. Best way to explain reeds is to equate them to a "flapper" when the engine is sucking fuel, the reeds fly open, hit the "reed stop" and open the block to the fuel. When the engine firing and not sucking, the reeds relax and go back to sealing off the block. The process is repeated each time the engine fires a cylinder. The reeds are pretty reliable and they are metal. Visualize a small tongue depressor made out of spring metal that is attached at one end and not at the other. It will deflect on suck and relax on fireing. As I said, the reed stop just stops the reeds from opening too far.
john in la
09-03-2007 08:00:31
 Re: O/T New Project......Boat Motor in reply to bo, 09-03-2007 07:47:34
So I can assume that as long as I only have sucking at the carb and it is not pushing pressure out of the carb the reed is working fine.
I really feel this missing part is my problem because there is nothing to stop fuel flow from the carb to the block. Just a open passage way to the side of the throttle flap.
Thanks for the help
John.
bo
09-03-2007 08:33:55
 Re: O/T New Project......Boat Motor in reply to john in la, 09-03-2007 08:00:31
"So I can assume that as long as I only have sucking at the carb and it is not pushing pressure out of the carb the reed is working fine."
Yup. Do a compression check for giggles. Need about 90 lbs to start that engine.
Parts for that carb may be a real bear to find. Go to the Sears website and see what they have.
Beau Jangles
09-03-2007 10:28:28
 Re: O/T New Project......Boat Motor in reply to bo, 09-03-2007 08:33:55
That item you, or the parts list describes as fuel pump is a quite common maladay that will result in a condition as you describe.
It is a flanged tube-like item made out of silicone or similar rubberish plastic. It is stuffed in a hole in the flange of either the carb or it's mounting flange.
If split on the tip it will flood and also not pump fuel too.
Last time I needed one it was a buck or two at the local Sears repair parts dept at the mall. And was a normal stocked item.
