Tractor Talk Discussion Forum
BCS tiller
Lanse
09-07-2007 16:02:21
I took the batteries out of my Mom's BCS tiller to charge it for her, and the twelve volt setting on my charger, well the needle went back and forth, back and forth. So I tried the six volt. Same thing. No the things arent on the termanials backwards. What do you think???
TomH in PA
09-07-2007 17:20:43
 Re: BCS tiller in reply to Lanse, 09-07-2007 16:02:21
How many amps was the charger set on? Use the trickle charge or 2 amp setting for a little battery like that.
Lanse
09-07-2007 17:31:21
 Re: BCS tiller in reply to TomH in PA, 09-07-2007 17:20:43
not 10 amp?
Gene Davis (Ga)
09-07-2007 18:35:19
 Re: BCS tiller in reply to Lanse, 09-07-2007 17:31:21
NO NO!! Too much amperge at once.
old
09-07-2007 18:08:02
Small battery low amps or you will fry the battery big time if not blow it up in your face. I know on the lawn mower 12 volt batterys the box says not to charge the battery at more then X number of amps because of the size of the battery
