Tractor Talk Discussion Forum
New Holland 6610S
prawnfarmer
09-08-2007 04:13:24
Replacing a JD2840 - any pros/cons on the 6610S? Will be used mainly for ditch bank mower, 7ft commercial tiller, transplanter-mulch layer, pumping water, pond-aeration, etc.
RodInNS
09-08-2007 19:46:55
 Re: New Holland 6610S in reply to prawnfarmer, 09-08-2007 04:13:24
They're a good solid basic specification tractor. The design is bulletproof, but the main drawback is the lack of reverse ratios in the transmission. If you can get past that, and don't mind a crashbox, go for it.
IT has '10' series styling but the guts of the tractor are from the '40/TS' series. It's got a Genesis engine and the modern castings. Again, a 40 series tractor with the manual 'style' 10 series controls and look. The transmission is bulletproof too, just lacking in reverse ratios.
Try one out and see how you like it. Should be a good solid tractor.
Rod
prawnfarmer
09-10-2007 04:03:23
 Re: New Holland 6610S in reply to RodInNS, 09-08-2007 19:46:55
Appreciate the advice - I have heard mostly positive things about the tractor.
