Tractor Talk Discussion Forum
farmall H gears
Peter Malsheske
09-08-2007 17:42:55
Does any one know if farmall H's came with more than one size first gear? If so,how many teeth? Where might I find them? My first gear seems to be higher than others I pull against. Thanks,Peter
No tools
09-08-2007 18:26:14
 Re: farmall H gears in reply to Peter Malsheske, 09-08-2007 17:42:55
suffix X6 low speed gears.
Grub
09-08-2007 17:57:24
On my M the serial number ended in X6 and that gave me a lower first gear. When I was in second I about matched speed with the other guys in first.
Grub
Janicholson
09-08-2007 17:48:25
Yes. They were an option. Availability is difficult to assess. The countershaft was milled into a gear for low, and the entire countershaft must be replaced as well as other components. A donor tractor, or complete rear half would be best. The serial number has a suffix (I can't remember what) for the low gear. Search Farmall IH forum for Low gear suffix. JimN
