Tractor Talk Discussion Forum
heavy duty antifreeze from wal-mart
61 uni
09-08-2007 18:40:52
Is this stuff any good? It was pricy, but it has the sca allready in it and is good for 12,000 hours. I put some in my diesel 2600 today. How does it mix with others? It is an orange color
John M
09-09-2007 08:34:30
 Re: heavy duty antifreeze from wal-mart in reply to 61 uni, 09-08-2007 18:40:52
Mixing it will cause your SCA level to drop. You should do a complete flush and refill. If I recall correctly, this is the same thing as Shells Rotella antifreeze, just relabeled for Wally World.
Bus Driver
09-09-2007 06:16:34
Sure, we all have seen antifreeze labeled as "heavy duty". Ever seen any labeled as "light duty"?
Dean Barker
09-08-2007 21:13:51
I've used Texaco's extended life anti-freeze (Dexcool) for gasoline engines for over 11 years now in both old and new vehicles with excellent results. The bad reputation came from GM using sealer in some of the new cars and trucks. I have also used the Texaco (now Shell) extended life anti-freeze for diesels for over 10 years again with excellent results. Benefits are no water pump failures, everything stays super clean, and no messing with scn's. This new orange anti-freeze will actually clean up a dirty system. Just drain after 50 to 100 hours and refill with new anti-freeze.
Dale B
09-08-2007 19:08:05
That sounds like GM's "Dexcool". There has been several discussions about this stuff here , including how it forms a cottage cheese sludge under certain conditions. Make mine green..... ....
Steven f/AZ
09-09-2007 05:00:24
 Re: heavy duty antifreeze from wal-mart in reply to Dale B, 09-08-2007 19:08:05
Dale B said: (quoted from post at 19:08:05 09/08/07) That sounds like GM's "Dexcool". There has been several discussions about this stuff here , including how it forms a cottage cheese sludge under certain conditions. Make mine green..... ....
The Dexcool causes problems in Dodge vehicles - something about the sealant they use with gaskets will loosen up with Dexcool.
Jon Hagen
09-08-2007 19:47:04
Does it say for use in diesel engines ? Diesel engines need a different additive package in the coolant to protect it from liner cavatation. You will not find the correct additive package in antifreeze intended only for gasoline engines, while the diesel rated stuff is good for either gas or diesel.
61uni
09-08-2007 19:57:58
 Re: heavy duty antifreeze from wal-mart in reply to Jon Hagen, 09-08-2007 19:47:04
yes, there is a picture of a semi on the front of it. It has the adative allready in it.
61uni
09-08-2007 19:30:20
it's not dexacool. It is aproved by CAT, Cummings, Navistar.ect
