Tractor Talk Discussion Forum
Oil leaks from oil pan
Hooper
09-12-2007 03:30:29
I replaced the gasket on the oil pan and have drips coming from the heads of the bolts in several places. Tried a rubber washer but still getting the leaks on them. Is there a sealant that will cure this? I tried permatex when I put the gasket on. This is on a Farmall C.
RayP(MI)
09-12-2007 08:39:20
 Re: Oil leaks from oil pan in reply to Hooper, 09-12-2007 03:30:29
Oil may be leaking through the threads, and then past the heads. Try taking out bolts, one at a time, cleaning oil off thoroughly, and reinstalling with a good RTV gasket sealer smeared on threads.
Revredneck
09-12-2007 06:34:09
Are you over tightening the bolts and squeezing the gasket out? Is the gasket sealing surface abslolutely clean and dry when you put the pan on? Let it sit overnight so all the oil can drip out of the block before you clean off the pan rails (use Brake cleaner on a rag) and reinstall the pan. Also, make sure the lip on the pan is good and straight. Take a hammer and a block of wood and flatten out around the holes. Hope this helps.
Good Luck and God Bless, ]
Tommy
