Tractor Talk Discussion Forum
JD 730 diesel Miss at Idle???
AWAbell
09-12-2007 20:06:47
I just bought a 730 diesel and it misses at idle or when driving it around unless it is under just a slight load then in fires on both cylinders perfectly.
Driving along it spits and sputters unless you just apply the brakes slightly to put it under a load and it runs great with the exception of alot of black smoke. I can't understand why
Bob
09-12-2007 22:53:12
 Re: JD 730 diesel Miss at Idle??? in reply to AWAbell, 09-12-2007 20:06:47
Is the "rack" set properly to "sync" the two injection pumps?
AWAbell
09-13-2007 17:30:36
 Re: JD 730 diesel Miss at Idle??? in reply to Bob, 09-12-2007 22:53:12
So that would effect it also at full throttle but not under a load. Because thats when it does it the most and puffs out a small bit of blue smoke, then when it starts to pull down a little it runs great.
AWAbell
09-13-2007 17:27:49
I have no clue. so when I get my book I will definetly check it.
thanks alot
mjbrown
09-13-2007 07:19:37
Good call! Sounds like one is at idle cut off when the other is at idle. I think sycronizing the rack is something that is best left to someone with the right equipment to get it right so both cylinders are making the same power. Perhaps there is an "in the field" way of doing it well but I don't know what it is.
