Tractor Talk Discussion Forum
Plowing in Ohio
Gene Dotson
09-12-2007 21:11:34
Been working the last few days plowing my 20 acres of wheat stubble. I used 3 different plows on the same Case 700 diesel tractor. Ground was very dry and hard when I started last Friday. I started with my old Case mechanical trip plow. 2-16 bottom with the old style resharpenable shares. This plow does a great job of penetrating hard ground. Just thought I would plow a couple rounds to scour it up good. Took 7 rounds in the long 10 acre field to scour it. Did such a good job that I plowed most of the field with it.
Got rained out Saturday evening and got 1 3/4 inches of rain. Monday morning I hooked onto the Oliver 3-16 pull type plow I bought last spring. I was amazed at how poorly this plow was set up and probably plowed over 40 years that way. The plow pulled sideways so hard that the rear of the landsides were completely worn away. I welded an old set of shares on for landsides. Moved the hitch to the right 5 inches, reversed the furrow wheel to get a full cut on the first bottom and adjusted the coulters. What a difference in performance. The plow does a beautiful job plowing and I have the straightest furrows I have ever plowed, not a weave, even in the toughest spots, and I plowed the entire field in 1 land about 350 feet across.
I plowed 1 round with my Case mounted plow, just to scour it up. Besides I had to hook onto it to move it out of the field. Broke a coulter stem when I lifted the plow. It does a decent job plowing, but doesn't have the depth control of the pull type plow.
The fields were getting overgrown with ragweed and foxtail, so wanted to get them turned under to rot before planting soybeans next spring. The ground here works much better if fall plowed.
I wonder how many plows are still being used without proper setup and how many were abandoned or cussed for doing a poor quality job of plowing.
Gene
higgins
09-14-2007 12:11:27
 Re: Plowing in Ohio in reply to Gene Dotson, 09-12-2007 21:11:34
A neighbor ruined a field when he got a bigger disk and ran either the front or back too low. Also made the mistake of doing it perpendicular to the road so we could all see. It took several years to get that field back level from the roly-poly!
Lee in Iowa
09-13-2007 20:04:41
Does anyone have any experience with a case 3 bottom 3 point rollover plow. I like the rollover so I can keep my uphill wheel in the furrow in the hills, but this plow doesn't seem to roll over far enough to turn the dirt over the way I like it. The weed seeds don't get buried good enough to stop them. There are adjustable stops but they adjusted as far they go. If anbody has ideas I'd like to hear them. Thanks Lee
flying belgian
09-13-2007 18:26:53
I did not no there was a 700 diesel. Thought they were called 800 when they were diesel.
John S-B
09-13-2007 11:51:39
I have an old Case BER 2-14 Eagle hitch plow I use on my Farmall M. I got it for $25. It works perfectly with my tractor, which is good because the adjustment on the hitch is rust bound and I cannot make any adjusment except for the 3pt. hitch.
JBMac
09-13-2007 08:35:32
What a good topic. I have a an old John Deere 3 bottom attached plow. I think it was a five originally, but cut the last two bottoms off. I think that the bottoms are 22" wide. My MF 175 can only pull it with two bottoms attached. In clay, it moves the front end of the tractor out of the ground and to the right- back up and try again less deep. My landside is also worn to a sharp point. When it engages the soil, it moves hard to the left against the check chains. I know that it is probably not set up right. I need to post a picture, perhaps you all could I.D. it so I can get an operators manual. It moints to the three point with a solid bar for the lower arms. One side is higher than the other, and is adjustable. Is this the adjustment, with a new landside, that will take care of the hard pull to the left? I assume that I shouldn't have to fight it so hard to plow. Should the plow pull behind the tractor without pulling hard on the check chains? It also lacks coulters. I try to disc first, to break the sod, then plow. This is old pasture I am planting hay in (Perennial peanut and bermuda. Mainly sandy with some clay. Some flint too, I'm glad the trips still work! Sorry for being long winded.
georgeky
09-13-2007 08:01:50
Around here most of them are ran out of adjustment. Some of these guys have been plowing all their live and can't adjust a plow. You can see every round too.
Leroy
09-13-2007 05:41:54
Gene, Probably a lot, also probably a lot of those owners did not even realize the plows were not set up correct or could do a better job. That is why a lot are satified with the very poor job the chisel plows do in some conditions.
Gene Dotson
09-13-2007 07:30:54
 Re: Plowing in Ohio in reply to Leroy, 09-13-2007 05:41:54
Leroy;
I have owned this farm for 5 years and worked every year to get the ground leveled out from poor plowing and tillage. I have finally gotten it pretty level and am now satisfied with it. Have knocked down all the headlands and filled all the dead furrows. Sure makes it a lot easier to combine the soybeans... Gene
