Tractor Talk Discussion Forum
MF 165 Hydraulics
Walter Buller
09-13-2007 11:40:36
This is about a 1970 model diesel. A hay baler works fine off the remote line but the lift won't pick up anything heavy until I rev up the motor to about 1800 rpm's, although it will pick me up at idle. Any ideas?
Leland
09-13-2007 19:01:13
 Re: MF 165 Hydraulics in reply to Walter Buller, 09-13-2007 11:40:36
Iused a 165 for years and they suck unless yopu are pulling wagons or raking hay ,they weren,t worth a crap for heavy work .
Bob N.Y.
09-13-2007 15:12:42
There are several different ways to hook up remote hydraulics on a 165. Some methods use the main hydraulic pump and some use the auxillary pump. The 3 point hitch works off from the main pump. Chances are your remotes are using the auxillary pump and the main pump is tired.
