OT What about this Ford diesel?
IaGary
09-14-2007 04:38:44
I have been told to stay away from that 6.4? ford diesel engine.
Stick with the 7.3 is what I was told.
Is the 6.4? that bad of engine?
What were its problems?
Was it a 6.4 or some other size? I don't know for sure.
Gary
BigMarv1085
09-14-2007 11:32:10
 Re: OT What about this Ford diesel? in reply to IaGary, 09-14-2007 04:38:44
Got a 1999 with 75,000 miles and have replaced the water pump,and a universal joint. Right it's needing a check valve in the vacuum system for the temp selector. Only bad thing I've heard on the 08 is it sits more than 2 months, if it doesn't start up pretty quick, it will bend 3 push rods. Know of three trucks that were waiting to have custom beds put on and that happened.
jp88
09-14-2007 10:03:07
The bullitin that I read was the exaust filtration which works like a self cleaning oven catches fire due to a leaky injecter or a leaking crack on the turbo assembly.So the turbo assembly and injecters might be a pain.I watched a video of a new 08 6.4 without the converters and filter setup with Flowmasters or something comparable on it and it sure got up and went in a hurry and sounded very good too.We have a 03 powerstroke that would scream and hold your head to the seat till the truck started ideling erratic.After 6 reflashes later it don"t jump at idle anymore but doesen"t have the power it used to have either,not even close to what it was.No leaks at 70k but did blow the turbo pipe off and had to have a new turbo and sensor under the turbo.
02XLT4X4
09-14-2007 07:21:14
The only problems I have heard with the 6.4 aside from the flamethrowing thing is that they are hard to keep on the lot.
The last couple years of the 6.0 were pretty good, however the first couple years got people like to talk them down like the old Chevy diesels and kind of killed their rep. The last couple years of the 6.0 trucks will be a bargain as everybody is still scared of the by then good engine.
unioncreek
09-14-2007 06:25:35
There's been reports of problems with the twin turbo's and Ford and Navistar are working to sort that out. There's alway problems when they come out with something new, it just takes a while to get them straightened out.
Bobg
Paul from MN
09-14-2007 06:16:05
Gary, In my opinion it is to early to tell how good the 6.4 is going to be. I agree with Kevin (FL) about the 1st two years of the 6.0
I have a 2005 6.0 50,000 miles (I know that is not much but it is all I can comment on) and no problems.
Straight highway driving lightly loaded it will get 18mpg. But put anything on it. I mean my fishing boat (aprox 3,000 lbs) to a gooseneck with tractors (aprox 15,000 lbs) and it gets 12-13.5
Allan In NE
09-14-2007 06:31:42
 Re: OT What about this Ford diesel? in reply to Paul from MN, 09-14-2007 06:16:05
Yepper,
That sounds just about right. Mine gets 17 empty and 13.6 loaded.
Allan
Tim Shaw
09-14-2007 10:53:18
 Re: OT What about this Ford diesel? in reply to Allan In NE, 09-14-2007 06:31:42
Did your old 7.3 get better that that? 17.5 mpg empty is about the best my "01 7.3L has ever done for me.
jdemaris
09-15-2007 06:35:15
 Re: OT What about this Ford diesel? in reply to Tim Shaw, 09-14-2007 10:53:18
I'm stilling driving a 94 turbo IDI 7.3 (not a Powerstroke) and a 1985 6.9 - which is basically the same engine as a 7.3. Neither are very good on fuel mileage - but otherwise great trucks. The 85 has 4.10 axles and no overdrive, whereas the 94 has 4.10 axles with overdive. Both extended cab and 4WD and neither has ever gotten better than 15.5 MPG empty on a flat highway. My 92 Dodge ex-cab, 4WD with 3.50 axles and OD via a Gertrag 5 speed man. has gotten 21 MPG empty - with the Cummins 5.9 turbo and intercooler. But to be fair, the engine is smaller and it's geared higher. But, it will outpull - when loaded - any of my other trucks.
Allan In NE
09-14-2007 12:56:01
Oh, oh, this isn't good. I feel like a rat in a cage 'cause you just caught me. Just like a kid with his fingers in the cookie jar. :>(
Dunno what the heck it got 'cause I burned tractor fuel in the silly thing.
That's why I'm so darned put out on this new one. Don't like paying the $3.10 a gallon for the new fancy fuel. :>)
Allan
jdemaris
09-14-2007 06:11:02
I know of many 7.3s with over 500K. Same with the earlier 6.9s that are just about the same engine. That being said, I've had a few GM 6.2s make it over 500K.
I think you are hearing the doom-and-gloom about the 6 liter engine - which Ford DID have many problems with. Ford is also involved in a law-suit with Navistar.
The new 6.4 - as least according to tests- is supposed to be an incredibly rugged engine. In reality - who knows? Makes no difference to me - since I'd never pay more for a truck then my farm cost.
Heavy duty auto engineers rate engine life with a "B" rating. For example, a B10 rating of 200,000 miles means - only 10% did not make it that far before a major teardown - and 90% did make it. And, that's with heavy duty use - not just cruising the highway empty.
The Ford 7.3 - or it's heavy-truck version T444E,
has a B10 rating of 200,000 mile and a B50 rating of 350,000 miles. So, half make it to 350K while being worked hard.
The new Ford 6.4 liter has a B10 rating of 262,500 miles - and a B50 rating of 375,000 miles.
Chevy Isuzu Duramax has a B10 rating of 220,000.
Cummins 5.9 has a B10 of 250,000 miles and a B50 rating of 350,000 miles.
The new Cummins 5.6 liter V8 is rated with a B10 of 325,000 miles.
Note that none of them come close to the Isuzu 6H that is used in some medium duty trucks. It has a B10 rating of 410,000 miles.
Paul from MN
09-14-2007 06:20:03
 Re: OT What about this Ford diesel? in reply to jdemaris, 09-14-2007 06:11:02
Where do you get those "B" ratings. They are very interesting.
jdemaris
09-14-2007 06:34:08
 Re: OT What about this Ford diesel? in reply to Paul from MN, 09-14-2007 06:20:03
Some sort of prof. automotive engineering publication. My wife's parents are both recently retired automotive engineers from Detroit - her dad from Ford and her mom from Chrysler - and I read a lot of their stuff when we visit Michigan. Her granddad - who just died at age 108 was a retired Dodge Brothers worker.
Vern-MI
09-14-2007 07:24:23
 Re: OT What about this Ford diesel? in reply to jdemaris, 09-14-2007 06:34:08
It is part of a Reliability Engineering statistical life data analysis. The results from Weibul, Minitab statistical analysis are used to predict the life of each individual component of an engine and also the life cycle of the complete engine. It's accuracy is extremely dependent on the variablity of the data collected and the condition of the tested parts which should represent the range of build or population of the production parts.
The B10, B50, & B90 curves presented on a chart of life cycles versus load with a certain degree of confidence should demonstrate the range expected life of the component or assembly if and only if all the variables have been presented properly. Here is where the results get real sticky. Have the entire range of variables been represented in the sample tests? Have the testing parameters been appropriate to the life cycle loads of the customer (typically 95th percentile). Is the sample size adequate to present the life cycle data with a degree of confidence necessary to not only provide a product that is going to be acceptable to the customer but also provide the company with a degree of confidence that they won't incurr excessive liability costs?
The compaines require that their suppliers use these statistical numbers to insure the relianbility of the product. One little snafu in component metalurgy, machining, casting porosity, fit and finish, can cause all sorts of havoc. that is why the companies have Black Belt Teams to quickly address any problems as soon as they become evident. They use engineers who have passed several hurdles of knowledge in statistical analysis, product design, production processes, etc. to develop the model that will predict the satisfactory product.
Occasionaly the system doesn't work because of an overlooked variable. For instance, say that a spool sticks in a bore less than ten percent of the time but it happens only during a Summer month of August and only at one supplier. First the data has to be collected to identify the variable condition then a team must be sent in to investigate the vendors process. When the team is sent in the company is producing parts to spec one after another and nothing shows up. Then the process gets even more detailed as they try to discover the unknown variable. After much study they find that one operator transferred to the casting process on the afternoon shift only during the vacation months of August is adding additinal casting release oil to allow the die cast body to be seperated from the die without any transfer of metal. It is producing a cold shut in the casting that after machining tends to catch the spool and cause it to bind. Solution, control the process by installing an automatic release oil injector which cannot be tampered with by the operator. Those are the easy ones but they do get through to the end customer. The more difficult ones are those that are in the original design and are not easily fixed by a process change. Those require a major redesign and a lot of cash to fix. Statistics are heavily used for all of the analysis in most cases they know where the product is weak and what the fatigue life cycle will be and so they constantly work to identify and correct those deficiencies.
Allan In NE
09-14-2007 05:05:21
Gary,
Think you must be talking about the older 6.0 diesel, which had some problems in the '03 model.
Allan
IaGary
09-14-2007 05:40:41
 Re: OT What about this Ford diesel? in reply to Allan In NE, 09-14-2007 05:05:21
What sizes are available in the last 3 years?
What's in your new one Allan?
Gary
Allan In NE
09-14-2007 05:59:56
 Re: OT What about this Ford diesel? in reply to IaGary, 09-14-2007 05:40:41
Let's see,
They went from the 7.3 to the 6.0 and the latest incarnation is the 6.4 with the dual turbos.
The '08s are a completely different ball game and redesigned from the pavement up. Bad points are that they are a "little spendy" and a bit thirsty on top of that.
Don't drive one 'cause you'll probably end up owning it. Just a total maniac for power with a ride like you wouldn't believe.
Allan
third party image
02
09-14-2007 10:04:04
 Re: OT What about this Ford diesel? in reply to Allan In NE, 09-14-2007 05:59:56
Quite a few radiators!
Allan In NE
09-14-2007 10:59:38
 Re: OT What about this Ford diesel? in reply to 02, 09-14-2007 10:04:04
Yeah,
7 radiators stickin' out there in the wind; what's up with that anyway? :>)
Allan
sd pete
09-14-2007 07:03:26
Looks like it would be a fun one to work on.
Allan In NE
09-14-2007 07:36:28
 Re: OT What about this Ford diesel? in reply to sd pete, 09-14-2007 07:03:26
Yeah,
They are built like the newer tractors in that the cab is lifted completely off the truck for most repairs.
Glad I'm out of the business. :>)
Allan
Kevin (FL)
09-14-2007 04:45:11
Gary,
We have a 2001 7.3--125,000 miles and it runs like the day we bought it. Heard the 1st two years of the smaller PS were bad. As far as I know the later ones are better, but I'm from the old school--more cubes is the way to get torque. The extra HP is gained for the newer engines by higher combustion pressures and higher RPM. Can't help but wonder if the smaller diesels will be able to go the distance. My brother's farmer friends in Mississippi have 7.3's that are pushing 300K miles. As for the current 6.4--someone that owns one can give their own impressions.
