Tractor Talk Discussion Forum
Will an 860 Ford lift a round Bale?
Phil Crome
09-15-2007 14:03:04
Folks,
I have a well-used and good-running Ford 860 and a need to occasionally move, not stack or load, some 13-1400 # round bales. Will my tractor move these wit a 3-pt. spear?
I have never tried it and am just wondering. I currently move bales with a Dew-Eze hydraulic bale bed on a pickup, which is nice, but occasionally the tractor would be handier.
Your thoughts are welcomed.
Regards,
Phil Crome
Bret4207
09-16-2007 06:51:56
 Re: Will an 860 Ford lift a round Bale? in reply to Phil Crome, 09-15-2007 14:03:04
If it's like my 800- no way.
alan bane
09-16-2007 06:25:46
Nope, don't try it.I have seen very small round bales it just may lift but that front end is pretty lite.
old
09-15-2007 21:23:24
With out weight up front nope not likely. That is one of the problems with the fords the front ends are to light. Now if you add a few hundred LBS up front it will play with a bale. My self I use a 841 with front end loader to move my bales and I have to have fluid in the tires and a back blade on plus 6 suit case weight s to move one of my 2000LBS bales using the loader
paul
09-15-2007 20:52:46
My 960 struggles to lift 5x6 bales, but it does. The front gets very very light, & I have a Schwartz wide front for a bit of extra weight....
--->Paul
RodInNS
09-15-2007 20:27:38
Yes, it'll probably lift the bale... or the front end. I'd start with a few hundred pounds of weight on there. Should be OK with that. I hauled a lot of bales on an 860 when I was younger. I also spent a lot of time steering on the brakes and driving with the front end in the air... Those bales were 1200#, give or take a bit.
Rod
RobMD
09-15-2007 18:27:33
build up a simple bracket to hang 4 Suitcase weights on the front
aFORDable
09-15-2007 14:28:33
It may lift it but you may have a problem keeping the front end on the ground. I have an 861 and I have run into the problem of the front end coming up instead of the bale lifting in some occasions.
