Tractor Talk Discussion Forum
O/T how to lay cermic tile
old
09-16-2007 16:05:05
I have a bunch of old ceramtic tile laying around and figure since I just put down new wood for the floor maybe I should put the tile to good use, but I don't know how to lay the stuff or what tools I might need or be able to get by with. So can any of you explain how to lay the stuff and what I will need to do so??
Thanks
Jrry
09-17-2007 06:38:57
 Re: O/T how to lay cermic tile in reply to old, 09-16-2007 16:05:05
Try diynetwork.com They have all kinds of do it yourself projects there with instructions.
cj3b_jeep
09-17-2007 05:14:12
Hey Old. It's best to have some serious backing under the tile. Something that won't give and break the tiles later. It's also best to use mixed mortar with the synthetic additives for a lifetime adhesion. Also, you don't have to lay the tile from the center, just lay it out from the center to make sure you have even pieces of tile on all sides.
msb
09-16-2007 21:10:07
If you have a Lowes around you, Old, they put of training schools for about every skill there is concerning home improvements. Check in the flooring department for a schedule. Its usually on Saturday mornings here.I used to lay tile a long time ago and I recently took the short schooling course at Lowes and learned a lot. Tiling has changed a bunch since I last did it.Its a lot easier now and the tools cost a lot less. An electric tile saw for $70 now.
Leland
09-16-2007 19:58:38
Hire it done belive me if you don't know what your doing ,then you will be money ahead in the long run
old
09-16-2007 20:55:37
 Re: O/T how to lay cermic tile in reply to Leland, 09-16-2007 19:58:38
Shoot if I could afford do that I would now have a new bath tub instead of one I have patched up. Plus I would have had some one else do the floors etc. Thats just not an option
Leland
09-17-2007 05:22:22
 Re: O/T how to lay cermic tile in reply to old, 09-16-2007 20:55:37
The only reason our B-room got tiled was beacuse my wifes aide at school boyfriend lays tile for a living and belive me it's not a job for a rookie .After watching him for a weekend I still would waste more than I layed .I traded him truck repairs in exchange for his labor ,maybe you could swing something like that with someonein your area
georgeky
09-16-2007 19:45:23
Rich, I have layed lots of tile. I start in the middle and work my way out to the walls. This way you have tiles that match on each wall. Just find the middle and chalk a line in each direction, apply the thin set and have at it. After all is set just fill in with grout and wash after the grout dries. You will need a tile cutter. They can probably be rented. Mine just scores the tile and then it will snap, like cutting glass. Some folks use a masonry type saw for cutting it.
omahagreg
09-16-2007 19:01:22
It is best to install a cement backer board first. It comes in 1/2" and 5/16" thicknesses. Also, use 'full flex' thinset glue, as anything else (at least what I have tried) will let go after it gets walked upon. Greg
Leland
09-17-2007 17:34:10
 Re: O/T how to lay cermic tile in reply to omahagreg, 09-16-2007 19:01:22
thats the best advice yet .
ILikeCase
09-16-2007 23:41:51
 ??? in reply to omahagreg, 09-16-2007 19:01:22
Desler?
John N Mi
09-16-2007 17:25:16
When working with the grout DO wear rubber gloves as the lime in the grout will eat your skin. Know from experence.
John
phillip d
09-16-2007 17:08:37
Laying tile really isn't all that bad at all.If you have 4 straight walls to work with,you have the battle beat!If you don't,start with the wall that you will notice the most.You will need to get tile glue,a glue trowell ,grout,comes in all sorts of colors,and some sponges.You apply the glue with the trowell in a workable sized area,maybe 3' at a time or so.If the tile doesn't have raised notches on all sides,you will need somthing to properly space the stuff,maybe 1/8" or so,to allow the grout to settle inbetween the tiles.After the tile is all down and set,atleast 12 hours,then you can mix the grout(cement) in an old ice cream dish.Apply the grout between the tiles and work it in alittle.Once it is almost dry,wipe off the excess with a damp sponge,not wet,just damp.The grout will shrink alittle,so it will need a second coating.You can use a masonary grinder disk to cut the tiles to fit. Just make a line,maybe half way through or so and snap it off carefully with plastic tipped pliers,or maybe put a cloth rag over the tile and use regular pliers.Best of luck and happy tiling.pd.
old
09-16-2007 19:13:33
 Re: O/T how to lay cermic tile in reply to phillip d, 09-16-2007 17:08:37
This is in a mobile home so there is not a single wall that is square. Oh well I'll do what I can and live with it. I just want to use what I have on hand and also protect the wood from water since its in a bath room
HENRY E NC
09-16-2007 18:53:48
A lot depends on the size of tiles and where you want to put them. Ceramic tiles are best set in a portland cement mix that you apply to the surfaces of the wall or floor. Also there is a latex emusion to add to the cement that will gaurantee adhesion to both tiles and floor or wall. Send me an email with some information or phone # and I will tell you more about the ease of tile laying. Henry hmmh@dnet.net
