Tractor Talk Discussion Forum
Briggs engine oil ?
1936
09-20-2007 04:48:17
17 HP motor need to know how much oil is needed in the motor and oil weight?
Rick Kr
09-20-2007 19:23:36
 Re: Briggs engine oil ? in reply to 1936, 09-20-2007 04:48:17
My B&S 32HP Vanguard takes 2.4 quarts according to the manual. Which should work out to 77 oz.
Rick
patsublett
09-20-2007 09:34:14
48 oz. Like someone said synthetic 10w-30 is a good choice.
JT
09-20-2007 06:45:58
Most Briggs engines take 20oz. for a push mower and 48oz for the bigger engines.
Jim
Chris in WI
09-20-2007 05:48:56
Whether its an OHV or valve in block, only add a quart and start checking. You will be close.
Bob
09-20-2007 05:37:25
If it's a (newer) OHV engine, Mobil 1 Synthetic is GREAT to help keep the valves from sticking, causing the pushrods to get out of place, and likely destroyed.
Jon Hagen
09-20-2007 10:51:05
 Re: Briggs engine oil ? in reply to Bob, 09-20-2007 05:37:25
As Bob says, use synthetic.
Briggs is very specific about matching the correct single grade of mineral oil to a specific temperature range, but they recommend multiweight synthetic oil for any load at any temperature. They even sell their own brand of synthetic engine oil
I use mobil 1 in all my small air cooled engines and love the performance and low oil consumption.
Here is a link to the Briggs oil chart.
Gary from Muleshoe
09-20-2007 05:19:09
This engine should hold somewhere around 68 oz. of oil. Use a good quality 30W oil. I use Quaker State in all my engines big or small.
When I am unsure of the exact amount I just add a little at a time and keep checking the dip stick. You should be safe to add 1 1/2 qt then start checking every little bit.
