Tractor Talk Discussion Forum
O/T: Ford 4.6 and 5.4 swap?
MeAnthony
09-20-2007 20:25:54
A friend of mine has a 1998 Ford van, E250, auto. It has a 5.4 in it, rod bearing is out. He can buy a 4.6 out of a Lincoln. Will these engines interchange? Or too many differences in electronics, bellhousing bolt pattern, etc?
Opinions and suggestions welcome.
Thank you for your time.
Anthony
JCSinGA
09-21-2007 11:59:36
 Re: O/T: Ford 4.6 and 5.4 swap? in reply to MeAnthony, 09-20-2007 20:25:54
I think there is a couple different versions of both engines and either may require the appropriate computer from the donor vehicle.
I've got a small used car lot and we have a '98 Lincoln Continental with the DOHC 32-valve 4.6 and I can bust just about anything on the road with that car, talk about a sleeper. WOW!!!
bradk
09-21-2007 08:55:34
It would be alot of self-inflicted pain.Why put a smaller engine in anyway?
RobMD
09-21-2007 08:03:04
Computers and wires and other stuff should be the deciding point for you. Find a drop in 5.4 and be done with it... no farting around with new computers and stuff.
dhermesc
09-21-2007 05:53:00
What's the year on the Lincoln engine? If I recall correctly the 1997 to 2002 have the plastic intake manifold - a $600 repair waiting to happen if it hasn't already been repaired. The 1991-1996 have the leaky valve stem seals (another $600 repair) that need to be replaced every 100K.
The transmission will bolt right up, but the computers issues need to be addressed.
Haywood
09-20-2007 20:49:05
Sounds like trouble to me!
Bob
09-20-2007 21:14:17
 Re: O/T: Ford 4.6 and 5.4 swap? in reply to Haywood, 09-20-2007 20:49:05
Wouldn't the "modular" 5.4 and 4.6 be (nearly) identical mounting-wise?
I don't know how confused the 'puter might get though, with it's "fuel map". I would THINK 'puter/emissions issues would be the big hurdle.
