Tractor Talk Discussion Forum
case tractor
lou ann william
09-21-2007 15:07:36
have a case tractor am wanting to sell. have serial number but can't seem to find the year. don't know what it is worth. needs some work. can anyone suggest where i could find this info
Joe (Wa)
09-21-2007 15:31:23
 Re: case tractor in reply to lou ann williams, 09-21-2007 15:07:36
If the tractor is 60's or older click on Serial Numbers on the left side of the page under Research & Info.
Joe
Tom Railsback
09-21-2007 15:25:45
Post the serial number; we can then tell you the year.
lou ann williams
09-21-2007 17:59:09
 Re: case tractor in reply to Tom Railsback, 09-21-2007 15:25:45
here is the serial number i got off the tractor. hope i looked in the right spot. i checked at the right and did not see mine. 708950sc forgot to put it in the last reply sorry
Gene Dotson
09-21-2007 18:39:13
 Re: case tractor in reply to lou ann williams, 09-21-2007 17:59:09
Lou Ann;
You are missing 1 number from the serial number. Sometimes there will be a number under the rivet on the left side of the tag. If it is a "4" it will be a 1944 model. If it is a "5" it is a 1953 model. Early in the 1953 model year, Case changed the numbering system and SC tractor serial numbers started with 8XXXXX ... Gene
lou ann williams
09-25-2007 14:06:56
 Re: case tractor in reply to Gene Dotson, 09-21-2007 18:39:13
Gene, you were right I missed a number. The serial number is 4708950sc. So this means it is a 1944 model, is that correct? Also does anyone have an idea as to what it would be worth? Needs new tires and a starter. My husband would tinker with the starter and get it to work. I am not so talented. Thanks for the info. Lou Ann
Tom Railsback
09-22-2007 10:50:46
Gene, wouldn't it be a 43 model if the first digit is 4? (47-4=43.)
Gene Dotson
09-22-2007 11:21:40
 Re: case tractor in reply to Tom Railsback, 09-22-2007 10:50:46
You are right Tom. I hit the wrong key and missed it when I reread it... Gene
lou ann williams
09-21-2007 19:19:54
thanks for the info. will check it in the morning and let you know
lou ann williams
09-21-2007 17:57:58
