Tractor Talk Discussion Forum
IaGary PTO on truck question.
rrlund
09-21-2007 15:48:57
Gary,I saw that pic you posted of your 79 with the PTO. What are you running that off of? I've got an 85 F250 Diesel 4x4 4speed manual. All the time I was hauling silage dump wagons with it,I was having to unhook and hook them to the tractor to dump them. I thought it would be a whole lot easier if I had a hydraulic pump on it. I've got a belt driven pump off of a combine that I could probably rig up somehow,but something running off a PTO seemed like a better idea to me.
Leland
09-23-2007 03:15:12
 Re: IaGary PTO on truck question. in reply to rrlund, 09-21-2007 15:48:57
Just find a junk yard that handles trucks they will have a pto and adaptor for you a lot cheaper than a new one . then all you need is a cable to engage it and a warning light so you don't forget to turn it off .
J Schwiebert
09-22-2007 09:29:59
Rick send me an e-mail with your phone number. Also look on your truck and see if you have a six bolt PTO opening on your transmission or transfer case. I still have my Chelsea PTO applications guides. J.
IaGary
09-21-2007 21:59:46
Its just a gear box that bolts to the transfer case similar to what trucks use to power the hydraulic pump on a dump box.
Instead of powering the pump I just ran the shaft clear out the back of the truck and put a 540 stub on the end.
Gary
Chris Jones
09-21-2007 16:43:31
Perhaps something like this would be simpler and maybe even more versatile. Link
