Tractor Talk Discussion Forum
Coop rear end has a goofy shaft
Jason Drabek
09-22-2007 05:02:40
I have a coop e3 with 2 different rear axles. I know that the splined axle is correct, but can anyone tell me off of what tractor that a keyed shaft would have come out of to fit the housing of did someone just rig it to work. The number on the hub is 3870Q63 and the key is 5/8 inch. Im just wondering?
Tradititonal Farmer
09-23-2007 00:25:41
 Re: Coop rear end has a goofy shaft in reply to Jason Drabek, 09-22-2007 05:02:40
The Cockshutt 30 (E3 COOP) ad two different style axle setup because the early setup leaked oil so bad
J Schwiebert
09-22-2007 09:26:11
You need to remember that rear end was built for Cockshutt by Timken. Now Timken also made that rear end for other manufactures. Maybe one of those had the keyed axles.
Jason Drabek
09-22-2007 13:29:08
 Re: Coop rear end has a goofy shaft in reply to J Schwiebert, 09-22-2007 09:26:11
where can I start looking for that kind of information? Who are the others? the axle is the the same per the wrong styled hub
