Tractor Talk Discussion Forum
Ford 6' flail mower
Chris King
09-25-2007 18:51:40
third party image
I have a Ford brand flail mower and I need the lower belt pulley that drives the drum with the cutters. It is 7.5" in dia. and has a 1.25" 10 spline center. I can't seem to find one anywhere but haven't actually called any of the dealers to ask. I see cutters, bearings, belts, and other consumables available, but no pulleys. Any body out there have any ideas?
I could also use a belt cover, but do have a homemade one.
Does anybody know what model it is?
The only info on the tag is Component #22-124 and Serial #5530.
Thanks for any info you may have.
The picture is one that looks like mine, but is only a 5'. Mine is definitely a 6'.
Chris
135 Fan
09-25-2007 22:22:40
 Re: Ford 6' flail mower in reply to Chris King, 09-25-2007 18:51:40
The one in the picture looks a little different from Ford flails I've seen but is smaller as well. Your mower is probably a 74 inch model 917 if I remember right. If you can't find a factory pulley, maybe you could find a pulley the same diameter with a smaller bore that could be machined to fit. Dave
Chris King
09-26-2007 03:10:07
 Re: Ford 6' flail mower in reply to 135 Fan, 09-25-2007 22:22:40
Thanks for the reply.
I've seen Models #907 and 917 listed a lot but can't seem to find the differences between the two. Is it the length? They use a lot of the same parts.
Thanks again.
Chris
