Tractor Talk Discussion Forum
1951 8N Lift
RDunster
09-27-2007 19:36:43
I cannot raise my 3pt lift with my Touch Control lever. I have to push the Position/Draft lever all the way down and hold it to lift. The touch control lever will let the lift down but won't pick it up. What problem might I have, what should I check or adjust. I'm new to tractors and need advice.
Bob
09-27-2007 21:19:42
 Re: 1951 8N Lift in reply to RDunster, 09-27-2007 19:36:43
At the very least, you need to adjust the position of the quadrant, and perhaps replace the cam follower pin.
Do a search in the archives over at the "N" Board for "N" GURU Zane Sherman's lift troubleshooting and adjustment instructions.
Also, pick up a copy of the I&T shop manual, FO-4 for these tractors. The manual is available from this very site, as well as MANY other sources.
