Tractor Talk Discussion Forum
Electric fence
37 chief
09-27-2007 21:41:02
I attached a electric fence charger wire around the base of one of my trees. The coons are going up and eating my fruit. If the coon gets past the base and is up in the tree, if he touches the wire will he still get a shock without being on the ground? I would get of the ground and try it, but I have been hit too many times by accident, and don't like it. Stan
farmerweber in PA
09-28-2007 18:07:08
 Re: Electric fence in reply to 37 chief, 09-27-2007 21:41:02
Got an old model 33 Remington .22 thats just the ticket.
Janicholson
09-28-2007 17:55:09
Put two strands of wire around the trunk on spool insulators. Place one wire about a foot off the ground, and 1.5 to 2" away from the tree. and the other about 4" above that one on the same type standoffs. Use a chunk of steel rod, or a fence post for a ground rod, and connect it to the bottom wire. Connect the charger, And Toast!!! JimN
fixerupper
09-28-2007 05:44:42
Make a platform in the tree and put a pan of flybait and Pepsi on the platform. They love the stuff. Jim
dboll
09-28-2007 05:11:32
run a ground wire close to the hot one, works for sheep
jjamna
09-27-2007 21:58:35
You might try a live trap with cat food. I have moved or removed 40 over the last 2 years. Game wardon said it was ok as long as I didn't kill them
Dave H (MI)
09-28-2007 07:03:13
 Re: Electric fence in reply to jjamna, 09-27-2007 21:58:35
Couple years back I had a terrible problem with coons tearing into buildings and killing poultry and rabbits. Found out a guy around the corner had started an animal removal business and was releasing them on his property. We had a talk and the problem stopped. Careful you don't get your britches full of rock salt when you drop them coons off!
Michael Soldan
09-28-2007 05:19:12
I removed 57 coons one year at the farm using live traps and cat food bait.Funny thing though, I had to tranquilize each one so I could let them out of the cage, I used Remington SuperX tranquillizers.
supergrumpy
09-28-2007 07:23:44
 Re: Electric fence in reply to Michael Soldan, 09-28-2007 05:19:12
Amen
steve in in
09-28-2007 05:50:06
I bought a little marlin 60 just for that same tranquilizing task. It worked real well. The hard part was digging them a new burrow about 4 feet down. Coons are burrowing creatures aren't they? :)
My game warden told me to just put them down. They didn't want them relocated to be someone else's pest.
IH2444
09-28-2007 09:10:28
 Re: Electric fence in reply to steve in in, 09-28-2007 05:50:06
Same here, but I usually use a 5mm sheridan air gun.
less noise and chance of damaging anything else.
I am planning on rigging a video camera to watch a metal bowl or catfood on rubber with metal under it. 220 fed thru lightbulb wired to the bowl and sheet metal with a remote relay to turn it on and off from inside where I will watch the video feed.
Capital punishment for Coons and Possums.
Mike (WA)
09-28-2007 11:31:31
 Re: Electric fence in reply to IH2444, 09-28-2007 09:10:28
As a lover of the universe and all that's in it, I should certainly be outraged by the mean spirited posts above. However, racoons and possums aren't included in my branch of PETA (People Eating Tasty Animals), so I guess I don't care.
Jon Hagen
09-27-2007 22:26:57
Unless it is very dry, the coon should still ground through the trunk.
