Tractor Talk Discussion Forum
starter steering wheel
Roy Haller
09-28-2007 08:33:21
HAS ANYONE MOUNTED STARTER ON 1939 IH W14 IF SO, WHAT STARTER DID YOU USE, ALSO LOOKING FOR STEERING WHEEL FOR SAME TRACTOR, BEST WAY TO GET REAR WHEEL ASSY OFF OF AXLES. THANK YOU ROY H HALLER
Roy Haller
09-30-2007 06:11:10
 Re: starter steering wheel in reply to Roy Haller, 09-28-2007 08:33:21
Thank you very much for info, still need to know about stsrter application and steering wheel. Roy H Haller
Athol Carr
09-28-2007 14:15:48
I used a pair of small (about 4 inches long) screw jacks between axle housing and wheel to start movement of wheel off axle on my 1937 O-12. The axle is slightly tapered and if the wheel has been there a long time would not want to move on the splines. Once movement started then not a problem apart from the great weight of the O-12 wheels
