Tractor Talk Discussion Forum
O. T. Dodge Ram 50 (1986)
Bill in Colo
09-29-2007 19:51:58
Can anyone tell me were the oil pressure sender is located 2.0 Mitsubishi motor?
Bill in Colo
09-30-2007 19:30:26
 Re: O. T. Dodge Ram 50 (1986) in reply to Bill in Colo, 09-29-2007 19:51:58
thanks.
mine has a idiot light
shannon from ohio
09-30-2007 12:36:07
I have a 1987 ram 50 same engine (It is BELOW the oil filter) easy too see..... .
Tim in NB
09-30-2007 08:45:29
By the picture in the service manual, it looks like it is beside the oil filter, right above the power steering pump. The manual has a simple way to test it.
1) Disconnect the wiring connector from the oil prssure gauge unit inside the engine compartment.
2)Ground, via a test lamp, to the front wiring harness connector.
3)Turn the ignition key to the on position.
4)Check to be sure that the teat lamp flashes and that the gauge's indicator moves.
