Tractor Talk Discussion Forum
carb
oliver man
09-30-2007 11:34:54
on my oliver 66 (my first oliver) i took the carb to an agco dealer to get the carb rebuilt and on my other 66 i decided to rebuild the carb on my own. they both ran the same but the carbs looked different. (the agco one was alot cleaner) how does agco get them so clean?
bradk
09-30-2007 18:39:39
 Re: carb in reply to oliver man, 09-30-2007 11:34:54
I use "Rust Eraser" made by Zep.Makes 'em look like new.
I use it on tractor and classic car guys carbs I go through. Non acidic and pretty cheap for a gallon.Have to have a local dealer to get the stuff. ~brad
Doug N
09-30-2007 13:58:14
They probably glass bead them. Alot of people on the forum don't beleive in doing it. I've been glass beading carbs for years and years and have NEVER had any problems with clogged passages from media. Just my 2. Doug N
TyTX
10-01-2007 06:54:42
 Re: carb in reply to Doug N, 09-30-2007 13:58:14
Jim Lincoln is an old school carberator mechanic who can take a rusty/crusty piece of junk and turn it into a like new carberator.
He always uses glass bead first, then completely strips them down and uses factory coatings to seal and preserve the base metal. They come back looking amazing and I've never heard of any problems.
Wish I had a glass bead cabinet.
RustyFarmall
09-30-2007 17:00:22
Doug, SHhhh, be quiet, now everyone knows the secret.LOL(:
doogdoog
09-30-2007 13:48:37
Aloha, They used to soak it in a 5 gallon pail of gunk but I don"t know if they still use it (EPA). Check out the auto parts (NAPA) and they may still sell it.
Mahalo,
doogdoog
K.W.
09-30-2007 12:19:07
I always use a wire wheel on my bench grinder to get them to shine. I first soak them in acetone for a day or two. Then wire wheel them clean. It makes them look brand new.
Dave H (MI)
09-30-2007 11:47:28
Did you soak it in a gallon can of carb cleaner? The sell them at the auto parts store. Comes with a little basket. Takes off everything.
rrlund
09-30-2007 12:05:07
 Re: carb in reply to Dave H (MI), 09-30-2007 11:47:28
What do they make to take the smell of that stuff off Dave? All you have to do is open the can and you stink for two weeks!
DRL
09-30-2007 16:03:34
 Re: carb in reply to rrlund, 09-30-2007 12:05:07
It sure has an odor about it. I came in one night after putting a carb in the bucket and my wife swore that it smelled just like her insulin. I didn't believe her, but she got out a vial and sure enough it did. Go figure.
rrlund
10-01-2007 13:17:52
 Re: carb in reply to DRL, 09-30-2007 16:03:34
Maybe you can just shoot her up with that stuff. Save money by buying it by the gallon. :)
kurt:ky
09-30-2007 11:47:16
Probably because of the carb cleaning solution and the agitation system they use to clean it.
Larry D.
09-30-2007 14:02:17
 Re: carb in reply to kurt:ky, 09-30-2007 11:47:16
OLIVER MAN... A Guy That does ALOT of Carb Work on Motorcycles Told me to use GREASED Lightnin',in Liquid form I have many Times will do a Great Job in a short Time, and will Melt that Gas Crud like it's nothing.. Larry KF4LKU
