Tractor Talk Discussion Forum
Removal of PTO shaft from 1963 International B414
Gary Hendsbee
10-01-2007 15:20:34
I own a 1963 International B414 gas engine tractor. I would like step by step instructions on how to take the complete PTO shaft out of the tractor.
Thanks for any help you can give.
jdemaris
10-01-2007 16:10:33
 Re: Removal of PTO shaft from 1963 International B414 in reply to Gary Hendsbee, 10-01-2007 15:20:34
Just unbolt the bearing flange where the shaft sticks out - and then it right out. Do it with the PTO lever engaged - it will keep the shift-collar from falling out once you pull the shaft. You need to drain the trans oil first - or - part the tractor on a steep hill pointing down - before pulling the shaft. Why are you pulling your shaft?
Gary Hendsbee
10-02-2007 16:19:02
 Re: Removal of PTO shaft from 1963 International B414 in reply to jdemaris, 10-01-2007 16:10:33
My problem is the shift collar is stuck on the front shaft. I am looking for any suggestions or ways to get at the shift collar to get it free either by taking out the complete PTO shaft or some other way to be able to do this.
jdemaris
10-03-2007 05:40:21
 Re: Removal of PTO shaft from 1963 International B414 in reply to Gary Hendsbee, 10-02-2007 16:19:02
I suppose, that if you pull the top cover off the trans you might be able to reach down to the shift collar with a pry-bar. The shift collar can be changed from the rear via the bearing-flange hole. Any work other than that will require splitting the tractor.
It's likely that the dogs on the gears have gotten peened over and thus caused the collar to get stuck on them.
