Tractor Talk Discussion Forum
belly mount sickle mower question
roger roland
10-02-2007 17:37:14
just wondering ... theres a sale coming up with kosh ? mid mount sickl mower off a H farmall , will this also fit the C ? or did they use a smaller unit or differnt ? as im not a H person dont own one & dont want one...
Harold Hubbard
10-03-2007 04:16:22
 Re: belly mount sickle mower question in reply to roger roland, 10-02-2007 17:37:14
I have been using a Kosch belly mount sickle mower on a Farmall C for forty years. Kosch built two basic mower units, a long shaft an a short shaft. Then they made mounting brackets for most of the tractors that were common at the time. I am sure that both the H and C used the same main unit, but the mounts were different. Usually when you find a used unit, unless it is still mounted, some or all of the mounting brackets are missing. The mower itself is about bulletproof, it uses IHC cutting parts which are still available from CaseIH.
If you would like pictures, post back and I will see what I can do.
ScottyHOMEy
10-02-2007 20:48:09
I have no knowledge of the particulars of the unit you're looking at. But I think you'd have to be a really good hand at geometry and welding both to modify the H rigging to fit it up to a C.
Don Hopf
10-02-2007 19:07:10
Dad bought one new in the late 60's and mounted it on a B Farmall. Still works today. Dad attached the mower to the center pivot for the swinging drawbar and the front of the mower to mounting holes in front of the battery using some 4 in. wide flat iron.
roger roland
10-02-2007 19:10:35
 Re: belly mount sickle mower question in reply to Don Hopf, 10-02-2007 19:07:10
i know they did make them for the A & b & c also but i think the H was a bigger thats what i really need to know
