Tractor Talk Discussion Forum
Charging Positive Ground
Glenn FiyzGeral
10-05-2007 05:08:42
How does one put a battery charger on a positive ground tractor? Do I need to disconnect the battery? It doesen's seem right to hook the positive clamp on a grounded terminal.
Glenn
David, Surrey UK
10-06-2007 07:36:25
 Re: Charging Positive Ground in reply to Glenn FiyzGerald, 10-05-2007 05:08:42
With a plough attached and in work, the tractor chassis should be pretty well grounded. third party image
David
Leland
10-06-2007 02:46:21
In the shop I worked in we always pulled the cables off any + ground then hooked up the charger .
buickanddeere
10-05-2007 19:21:47
There is no ground on your car, truck or tractor. There is a ground on the AC equipment in your house, barn & shop. Your car, truck or tractor has a "chassis return".
bill mar
10-06-2007 05:49:34
 Re: Charging Positive Ground in reply to buickanddeere, 10-05-2007 19:21:47
everyone I know "refers" to it as a ground.
Gerald J.
10-05-2007 07:40:10
In some metal cased chargers the case is connected to the negative output so you don't want to set the charger ON the tractor where it can tough the tractor or it will short the battery with positive ground.
Gerald J.
Coloken
10-05-2007 07:50:55
 Re: Charging Positive Ground in reply to Gerald J., 10-05-2007 07:40:10
Gerald, so right in some cases. Very important on those tractors that use two 12 volts for a 24 volt system and you are charging one at a time. Not a bad idea in all cases.
NEsota
10-05-2007 07:04:07
Gleen, On so many automobile repair instructions they advise; disconnect the ground. If we all asked more questions and got good advice it would save some screw-ups.
Walt Davies
10-05-2007 07:30:44
 Re: Charging Positive Ground in reply to NEsota, 10-05-2007 07:04:07
On the newer cars this is good advice because of the many computerized items in them, but on an old antique tractor it really doesn't matter that much.
Walt
John T
10-05-2007 05:33:36
Glenn, Stop n think, as far as the relationshiop between the battery and charger (+ to + - to -), what difference does it make that a big hunk of iron (tractor) just happens to be hanging onto one of the battery posts??
John T
Tom N OK
10-05-2007 05:18:48
Hi Glenn Don't need to disconnect...just hook your battery charger positive to positive and negative to negative.
Tom
glennster
10-05-2007 05:18:41
hook the charger up, postive to positive, negative to negative. the charger doesnt care which post is used as a ground.
Allan In NE
10-05-2007 05:18:38
Forget what/how the battery is mounted on/in and concentrate on the battery itself.
Positive to positive and negative to negative. :>)
Allan
Triplerange
10-05-2007 06:29:58
 Re: Charging Positive Ground in reply to Allan In NE, 10-05-2007 05:18:38
Aww...come on guys...he could just see which way arcs the most and smokes the charger...then NOT use that one! (j/k...don't try it...dangerous)
flashback
10-05-2007 06:59:18
 Re: Charging Positive Ground in reply to Triplerange, 10-05-2007 06:29:58
I just bought a new 6/12 volt charger and the instructions say never to place the positive on the battery in a positive ground situation, hook it to a good ground on the metal itself. Seem to work fine for me.
Coloken
10-05-2007 07:45:53
 Re: Charging Positive Ground in reply to flashback, 10-05-2007 06:59:18
Sheeee...Wonder if that was writen by the same guy in China that writes all of my computer instructions. Charger should be hooked as close as posible to the battery, not out on some external wire connection. All though any where will work.
Coloken
10-05-2007 07:55:45
 Re: Charging Positive Ground in reply to Coloken, 10-05-2007 07:45:53
So I blew that one...They do that so the spark, if there is one, is not right at the battery. Too early in the morning.
