Tractor Talk Discussion Forum
Shocking corn
steelfronts
10-05-2007 16:25:39
How do you make a corn shock? I got my binder working good cut some corn and tried to make a shock .Failed. Corn is still alittle green eight feet tall with real high placed ears. I have set the binder to tie as high as possible. The tie is still beneath the ear. Any help thanks
Leroy
10-06-2007 08:40:06
 Re: Shocking corn in reply to steelfronts, 10-05-2007 16:25:39
All the other posts about a shock horse are missing one detail. It is as they say a large saw horse with only one set of legs with the top rail resting on the ground at the end without the legs. Now for the missing part, a couple of feet from the legs there is a hole drilled in the top part. Use that hole to stick an old broom handle, head cut off. That will make it so that when you start to set the bundles they do not slide along the top rail and fall to the ground. Put the first bundle against the broom handle from the low side, then put the second bundle against the handle on opposide of rail, now go to top side of handle and put one in each corner and continue adding one bundel to each corner till you have 12 or 16 bundles set up, have to keep equall all the way around or weight will cause shock to fall over. Same method can b e used with hand cut and armload carried stalks. now pull the handle out, now pull the top rail out pulling on the legs so there is nothing to stop the top rail from pulling. Now you can continue adding more bundles one at a time working around the shock going to opposide sides to keep weight ballanced till you have it as large as you want it. Then take a piece of rope and pull the shock tight so you can put a piece of twine around at rope height to tye shock together so it does not fall over
NEsota
10-05-2007 19:06:49
We used a horse like the one RayP talks about except the dimensions on ours were larger. Two pieces of wood, about four feet long (1"x4") were fastened at the top and spread 30 inches, at the bottom. These were held by a horizontal piece of the same material about a foot off the ground. The third leg was attached at the top of the "A" and was 8-9 feet long. You put the first bundles on either side of third leg at the high point, until they support one another and then pull the horse through on the open side.
HENRY E NC
10-05-2007 16:56:38
you must put one bundle in the middle with the bottoms spread ou in a circle and then lean the others around it. I never shcked corn that was tied by a machine as all ours was cut and tied by hand. Shocked lots od wheat and oats off of a binder though. Same idea.
RayP(Mi)
10-05-2007 18:12:09
 Re: Shocking corn in reply to HENRY E NC, 10-05-2007 16:56:38
Remember my dad and uncle doing that. They had a tool made like a sawhorse - one end, (legs on other end missing.) This made a tripod, about 3 1/3 feet high, main beam was probably 5 to 6 freet long. They"d drag the "horse" along, stacking 3 or 4 bundles against it, tieing them, and dragging the "horse" to the next spot.
