Tractor Talk Discussion Forum
OT Gas from air filter on generator?
Dave H (MI)
10-07-2007 17:09:52
Not entirely OT as I am putting the tractors to bed for the winter and realized my Honda genny has been sitting back there for a couple years without being run. LSS, I decided to put some fresh gas in with the old and just try to start her. They are usually pretty forgiving engines.
It fired up, idled down, ran about ten seconds and then stalled, burped, and about a quart of gas came out through the air cleaner all over the floor. Anyone have the slightest idea why this happened? I have run lots of neglected engines...they either start or no....but have never seen the likes of this.
soundguy
10-08-2007 05:26:18
 Re: OT Gas from air filter on generator? in reply to Dave H (MI), 10-07-2007 17:09:52
I agree with Bob.
Float needle/seat issue.. needle is stuck open.. etc.. letting gas overflow carb.
That's why my genny has a pto shaft and hooks to my tractor.. i got tired of rebuilding small engine carbs all the time cuz they are so junky..
Soundguy
Bob
10-07-2007 17:30:26
What's so unusual about it? OBVIOUSLY the needle and seat assembly either has crud in it or is stuck open, so the float can't shut the gas off when the float bowl is full. Happens ALL the time, even with old tractors. MANY engines wind up with the crankcase full of gas when this happens, on your's, the gravity assisted path out for the gas was through the air filter, onto the floor.
Paul from MI
10-07-2007 17:26:55
Sounds like maybe a stuck carb. float? Ran a little. then totally flooded. Did you shut off thge gas and run the carb dry when you last ran it? Then maybe when you turned the gas back on enough ran in the carb to start it, then it flooded. Just a guess. Might want to fix it soon. I ran soybeans yesterday in 87F temp, felt more like I should be combining wheat in July than beans in Oct. Winter may be coming someday--never know in MI.
Paul
KEH
10-07-2007 17:22:40
I really don't know, but is it possible that a valve was stuck open in the carburator, allowing gas top drain from the tank into the crankcase? Cranking the engine might cause the gas to leak past the rings into the cylinder and as the engine choked down the piston kicked back pumping gas back through the carb. I had gas leak into the crankcase on a Snapper lawnmower with a horizontal shaft Briggs engine and it got gas into the cylinder. Drained crankcase, put in new oil, took spark plug out, turned engine over after fixing plug wire so it wouldn't spark and ignite gas, and pumped gas out spark plug hole and exhaust pipe. had a clean engine which needed to be broke in again. Curious to know the cause of your problem.
KEH
