Tractor Talk Discussion Forum
O/T Ford V8 Motor Governor
37 chief
10-08-2007 19:11:48
I have a chipper with a Ford 330 cu in motor. If I wanted to put a governor on this motor, how difficult would it be? Stan
Russ from MN
10-08-2007 19:23:21
 Re: O/T Ford V8 Motor Governor in reply to 37 chief, 10-08-2007 19:11:48
I have often wondered if a cruise control from an older vehicle wouldn't work, in the mid 70's they had aftermarket ones that were simple to install, and would maintain a set speed of the drive shaft.
Chris(WA)
10-08-2007 19:50:00
 Re: O/T Ford V8 Motor Governor in reply to Russ from MN, 10-08-2007 19:23:21
I'm with you Russ. I bet it would work. For a hundred bucks it would be worth a try. An Audiovox CCS-100 should do the trick. They sure work good on trucks and vans as cruise units.
Bob
10-08-2007 19:20:51
Use a belt drive Pierce or Hoof governor. It takes some fiddling to get the linkage travel all figured out.
A source is certain old combines and swathers, and other power units, or you can buy a ($$$) new one.
I don't think THIS site has them... you migh call them and ask. Their competition does, though.
If you would like a link to that source, email me.
bigcoulee@hotmail.com
37 chief
10-08-2007 23:14:18
 Re: O/T Ford V8 Motor Governor in reply to Bob, 10-08-2007 19:20:51
Bob Thanks for the names, I found one on EBAY. Stan
Tom43
10-09-2007 09:58:52
 Re: O/T Ford V8 Motor Governor in reply to 37 chief, 10-08-2007 23:14:18
Dear Chief,
New Holland bale wagons used a Ford 330 motor with a governor
Bob
10-09-2007 14:27:54
 Re: O/T Ford V8 Motor Governor in reply to Tom43, 10-09-2007 09:58:52
NH combines, as well, used Ford V-8's, with a governor.
37 chief
10-09-2007 17:34:15
 Re: O/T Ford V8 Motor Governor in reply to Bob, 10-09-2007 14:27:54
Looks like a couple good leads for a governor. Is there a bone yard anyone can recommend who might have a ford governor? Thank's Stan
