Tractor Talk Discussion Forum
Sickle mower pit man
Don Hopf
10-09-2007 07:52:24
Broke a mower pitman on a Kosh sickle mower, which uses IHC parts. Where can i get a inexpensive replacement?
Thanks Don
IA Roy
10-09-2007 19:24:42
 Re: Sickle mower pit man in reply to Don Hopf, 10-09-2007 07:52:24
Cut one from a fir 2 x 4 some years ago for my fil. I think it worked ok. We cut an extra just for the heck of it. Fir is tough and impact resistant.
IA Roy
10-09-2007 19:24:19
Wayne from MN
10-09-2007 11:02:27
If you purchase a universal fit pitman, you should assemble the sickle end first, attach to the sickle, adjust the "register" (sickle sections are centered in the guards at the extreme end of outward travel), rotate the pitman drive to the extreme outward travel position, and then mark where to drill the drive end holes.
This proceedure will assure that the sickle will give you a full cut(centered in guards at both the in and out travel limits).
Take your time and the result will be worth your efforts.
Walt Davies
10-09-2007 08:52:34
They have them at moc.tlib-ulav or try the phone number. 6723-828-888-1
Walt
soundguy
10-09-2007 08:35:12
I believe I have also seen a universal ( u-fit ) pittman arm at TSC.
Soundguy
Bob
10-09-2007 08:09:02
What do they cost at CNH?
I bought a couple for DEERES I'm fixing up, this fall, and could believe how CHEAP they were, about $16.00 for a # 5 pitman, stick, for example.
That must be the cheapest part on their shelves, nowadays!
36 coupe
10-09-2007 14:40:24
 Re: Sickle mower pit man in reply to Bob, 10-09-2007 08:09:02
Just paid 24.96 at cnh dealer.TSC didnt stock the one I need.Catalog says 10.00.I will start making my own from ash,hickory dosent grow here.
M Nut
10-09-2007 08:01:37
I Used to just cut my own out out white oak lumber. Use the old one for a pattern, and your good to go!
John (MO)
10-09-2007 09:16:40
 Re: Sickle mower pit man in reply to M Nut, 10-09-2007 08:01:37
I use hickory, seems a bit more flexable than oak.
M Nut
10-09-2007 10:01:30
 Re: Sickle mower pit man in reply to John (MO), 10-09-2007 09:16:40
Could be. I don't have any experience with hickory. It doesn't grow where I live.
glennster
10-09-2007 07:59:14
farm and fleet sells a universal fit pitman arm, you cut and drill it to fit your mower. last one i got was around 10 dollars or so, use the old pitman as a template.
Don Hopf
10-09-2007 12:19:50
 Re: Sickle mower pit man in reply to glennster, 10-09-2007 07:59:14
Thanks for the replies. I tried TSC store. Only had a NH one (had the right number of holes but two inches too short). I'll try CIH next. If the price is high, the the local lumber yard for some oak
Don
36 coupe
10-10-2007 02:05:29
 Re: Sickle mower pit man in reply to Don Hopf, 10-09-2007 12:19:50
CNH dealer price is double TSC.TSC store Im headed for today has a universal type for 10.00.They have 16 pitman sticks in the catalog but only stock 3 types in the store I go to.Drilling and slotting is not an easy job but I will make my own after paying double for the last one.There is less than a board foot in a pitman stick so you are paying 50.00 a board foot at the CNH dealer.Make sure your blanks have a straight grain and avoid red oak.
Don Hopf
10-12-2007 11:02:18
 Re: Sickle mower pit man in reply to 36 coupe, 10-10-2007 02:05:29
Got one at the CNH dealer for $15.00 ready to bolt on.
