Tractor Talk Discussion Forum
case ih 885 clutch noise
dlmslm
10-10-2007 17:50:07
my case ih 885 is making a squealing noise when i push in the clutch, but some time it makes the noise and some time it won't. i would like to know if anyone else has had a similar experience,and what it is that is causing the noise. thanks
495man
10-11-2007 16:30:39
 Re: case ih 885 clutch noise in reply to dlmslm, 10-10-2007 17:50:07
Sounds like throw out bearing is in need of grease or "shot" There should be a grease fitting on the side of the clutch housing for this. If that doesn
t fix it, you"ll have to split the tractor, depending on the hours on the machine likely a whole clutch job is prudent, seems to me the clutch job on our 495 a few years back was well over a grand or so including machining the flywheel.
Trkr
10-11-2007 10:37:16
Don't know if you can grease a 885 throw out bearing or not,lot of them are sealed and if its squeaking its shot.Check and see if there is access to it and if its greaseable.If it is the throwout bearing,yes fix it right away,it can get worse in a hurry.Can eat the fingers off your pressure plate.The tractor will have to be split,and you should put in a new clutch assembly at this time because of the labor involved.Call a couple of dealers and get a price to split and put in a clutch assbly.
dlmslm
10-10-2007 18:26:36
should it be fixed right away
Weldon K
10-10-2007 19:03:12
 Re: case ih 885 clutch noise in reply to dlmslm, 10-10-2007 18:26:36
"should it be fixed right away"
Very soon , at least.
dlmslm
10-10-2007 19:50:08
 Re: case ih 885 clutch noise in reply to Weldon K, 10-10-2007 19:03:12
what is a ball park figure for having this work done
LenND
10-10-2007 18:09:33
Yeah! Sounds like it about as dry as it can get. Time for a new one maybe.
Allan In NE
10-10-2007 18:04:46
Gotta be a throw-out bearing, don't ya think? Sounds like the classic symptom.
Allan
marlowe
10-10-2007 18:10:06
 Re: case ih 885 clutch noise in reply to Allan In NE, 10-10-2007 18:04:46
10 to 1 throw out bearing
