Tractor Talk Discussion Forum
Oils
hopfarm
10-11-2007 03:20:29
Rebuilding a Farmall C and have replaced bearings, seals and gasket on a rear axle. Have the rear end drained and top cover off. I am scrapping the slude off the bottom of the housing. I have two questions. What can be used as a solvent to clean the housing and am planning to replace fluid with universal trans-htdraulic oil. Is this way to go and will it work in my touch control hyd. system. Appreciate input.
Steven f/AZ
10-11-2007 07:44:46
 Re: Oils in reply to hopfarm, 10-11-2007 03:20:29
I"ve used kerosene and diesel fuel to help clean out the sludge. Buying the actual solvent works too, and it is less combustible.
Use SAE 90 or 85w-140 in the rearend and transmission. Hydraulic/trans fluid will be too light and the gears will spin forever when you push the clutch in.
Use a hydraulic fluid in the touch control system.
soundguy
10-11-2007 07:35:05
Ditto what johnm said.. kero.. diesel.. mineral spirits.. etc...
soundguy
John M
10-11-2007 03:45:46
Kerosene in a garden sprayer works for me, b ut put 90wt in the transmission, the hydraulic are seperate from the transmission.
