Tractor Talk Discussion Forum
What would you do
alan bane
10-11-2007 08:37:45
I have a Ford 860 tractor and last year it blew a head gasket. I had the head shaved and put it all back together and in time there were tiny bubbles around the gasket. I have been told to leave it alone and others told me it would blow again if it weren't fixed.You people seem to know quite a bit about these type problems, so what would you do?
CCer
10-11-2007 14:52:20
 Re: What would you do in reply to alan bane, 10-11-2007 08:37:45
Bought a used truck, recently overhauled Cummins.
It put out little bubbles too. As I ran it, it dried up.I was happy. One time I put power cleaner in the fuel. That started it leaking/bubbling again. I guess it was sealed? by carbon/soot. Watch oil and coolant, run it.
Dick L
10-11-2007 12:06:01
Call your Ford dealer. They will most likely tell you to put in a can of Barrs leak and forget it. The fellow I bought my first Oliver 1850 from had the head surfaced twice to try to stop water seep from between the head and block. He told me on the phone he would sell it as is. I called the Oliver dealer and he told me that it was common and that Oliver had sent the dealers a notice to put in a can of barrs leak after putting on a new head gasket. I did just that and it never gave a problem.
bradk
10-11-2007 11:09:14
I have an Oliver 88 diesel that's been doing that ever since I could remember.Hasen't gotten' worse or better,doesn't affect performance.
alan bane
10-11-2007 10:28:30
Bill, never checked the block, Rob the gasket was put on correct, Blue, not sure about the torque wrench being calibrated correct, Buick-Deere, did use the old head bolts and just wiped them off but didn't clean them with any solvent and not sure about the sleeves.
Bill46
10-11-2007 10:05:43
Did you put a plane on the block? The head can be perfect, but it that block is not right it will not seal right...just my 2 cents.....
Janicholson
10-11-2007 09:52:46
I would use three tablespoons full of ground fine ground black pepper in the radiator. Believe me, it gets into and plugs minor leaks pretty well. If it is not leaking coolant beyond the small bubbling, I would run it. JimN
RobMD
10-11-2007 09:22:10
Did you put the gasket the right side up?
evielboweviel
10-11-2007 08:41:49
Retorque the head
Ron
alan bane
10-11-2007 09:07:09
 Re: What would you do in reply to evielboweviel, 10-11-2007 08:41:49
We did that,we torqued at 65 ,let the motor get hot and then torqued at 70, still showed tiny bubbles and then retorqued at 75 and bubbles were less but still there. The correct torque is 70.
blue3992 (N illinois)
10-11-2007 10:06:58
 Re: What would you do in reply to alan bane, 10-11-2007 09:07:09
Are you sure your torque wrench is calibrated properly?
buickanddeere
10-11-2007 10:09:52
 Re: What would you do in reply to blue3992 (N illinois), 10-11-2007 10:06:58
I 100% agree. I wonder if they reused the old head bolts and didn't chase the dirt/rust out of the block threads? Wet or dry sleeves or investment cast block? Uneven sleeve protrusion is a sealing problem looking for a place to happen.
alan bane
10-11-2007 10:36:31
 Re: What would you do in reply to buickanddeere, 10-11-2007 10:09:52
I ran the tractor all summer and probably lost 1/4 to 1/3 cup of water from the radiator total. I have to put a new radiator on the tractor and since I have to take the hood completely off , I thought I would try to fix the problem with the head gasket but if I knew it wouldn't hurt anything ,I'd leave it alone.
