Tractor Talk Discussion Forum
Clevelan tractor company ID of unusual tractor
Tom Lykins
10-11-2007 19:56:17
Here is a link to pictures of a tractor that no one as of yet can id.
The engine is newer than the 1919 Possibly Model H cletrac.
However there is a difference in the three wheels on each side of the tractor and the noneclature plate is a cleveland not cletrac or oc
horsedesigns.com/cleveland
the engine has cast numbers1044371 on the left side
071 301 01 00 on the right side
possibly a experimental model? any help ? thanks Tom
Tom Lykins
10-13-2007 17:54:53
 Re: Clevelan tractor company ID of unusual tractor in reply to Tom Lykins, 10-11-2007 19:56:17
Actually the R , H, W series were closer to the one I have They were before 1920 and The H and W came with the steering wheel not exclusively. This unit has some modification , some looks much later ( engine and the big middle sprocket) earlier
head scratching , big time...
Thanks Tom
Walt Davies
10-12-2007 09:26:30
Would this one be close it was made from 1926 to 1930 My shows it as the only one with a steering wheel.
Walt third party image
Tom Lykins
10-12-2007 07:03:56
Thanks Ron
I found that the Clectrac H series closly resembles this and there are some holes low in the frame where the idlers would go. I don't find anywhere a tractor with a large middle sprocket like this. Is this the punch holes you speak of for the large sprocket? This is out of my league, my neighbor found a 45 Case VAC and this tractor. The case started right up with a little TLC The unknown will take a little more.
Thanks again Tom
Tom Lykins
10-12-2007 07:03:47
Thanks Ron
Thanks again Tom
Paul from MI
10-12-2007 04:06:56
Cleveland Tractor Company was the maker of Cletrac tractors. This one has been repowered with a much newer engine of some type, probably automotive by the looks of the starter solenoid, etc. and the ready strut prepunched angle iron bracing. Looks like quite a project.
Paul
