Tractor Talk Discussion Forum
MCcormick farmall super c
chris and jerem
10-12-2007 11:42:50
Need to know how to hook up the hyd. hoses from MCcormick farmall front loader to tractor.
Dale inAr.
10-12-2007 19:01:15
 Re: MCcormick farmall super c in reply to chris and jeremy, 10-12-2007 11:42:50
Where are you located??? I have the set up for a bucket system.Even have the arms,valves and the block to direct the flow to a bucket.If you were close enough,I would let it all go for 100.Just don't have a bucket for it to make it complete.If you are interrested let me know.I'm in the Northwest corner of Arkansas.
chris and jeremy
10-16-2007 09:58:26
 Re: MCcormick farmall super c in reply to Dale inAr., 10-12-2007 19:01:15
i am interested and the price is good can u send phone number i am located in s w missouri very interested
Janicholson
10-12-2007 11:59:38
If you hafe a diverter bloch between the steel tubes and the touch control unit connect the valving in there. If you don't you need one! JimN
chris and jeremy
10-12-2007 12:03:38
 Re: MCcormick farmall super c in reply to Janicholson, 10-12-2007 11:59:38
we got one of those can i hook my hyd hoses for the rams to the tractor and will one of the control levers by the steerwheel operate it
Janicholson
10-12-2007 12:15:06
 Re: MCcormick farmall super c in reply to chris and jeremy, 10-12-2007 12:03:38
No, those are internal only, THe plumbing needs new valves (open center) with pressure from one port of the block, and return in the other. JimN
chris and jeremy
10-12-2007 12:39:06
 Re: MCcormick farmall super c in reply to Janicholson, 10-12-2007 12:15:06
do u know where i can get the stuff to hook it up with
Janicholson
10-14-2007 12:24:33
 Re: MCcormick farmall super c in reply to chris and jeremy, 10-12-2007 12:39:06
There as many places to get components as there are towns with TSC, Farm Fleet, Fleet Farm, hydraulic shops, and CaseIH dealers. All of them have the parts, and hoses to make it operational.
Post questions over on the Farmall IH discussion board above to get more info. Sense we can't see what you have, it is difficult to give you pointers. Each cylinder that is two way needs to be connected to the end ports in the valves. So that when lifting, the other side of the cylinder discharges into the return through the other port. Google basic hydraulics systems to get some diagrams. Open center is a must!!
JimN
