Tractor Talk Discussion Forum
farmall 230
mel140
10-17-2007 11:01:20
how do you time the crank gear and the camshaft gear.the cam gear has 2 marks on one side and 1 mark on the other side.tks for any help.
Steven f/AZ
10-17-2007 12:08:49
 Re: farmall 230 in reply to mel140, 10-17-2007 11:01:20
Look at the crankshaft gear and the magneto gear for timing marks.
If the crank gear has two dots, the one dot goes between them. If the crank gear has one dot, then it goes between the two dots on the cam gear.
Same story for the magneto/distributor drive. Line one dot in between two.
Darin in Nebraska
10-17-2007 11:59:22
On my 240, it has the C-123 engine in it. I timed them together. I put the one mark between the 2 other marks. Not sure what motor you have but that's how my manual said to do it.
Thanks Darin
