Tractor Talk Discussion Forum
Zenith Carburetor
steve duplechin
10-17-2007 12:43:21
I am rebuilding a Zenith carb. Two of the brass jets are varnished and stuck in the carburetor. I tryed soaking for days and still can not get them out. Anybody got an idea on what to do.
steve duplechin
10-18-2007 04:30:11
 Re: Zenith Carburetor in reply to steve duplechin, 10-17-2007 12:43:21
The jets have a slot in them for a screwdriver to fit, so I assume they are made to come out. The top half of the carburetor is cast iron and the bottom half is cast aluminum. Do you think heating the aluminum would create a problem? This carburetor is a Zenith 12293-B and goes on a Continental F140 engine that is on a Massey Ferguson Super 35 combine. Thanks for your help.
Maark
10-17-2007 14:43:59
You can heat the cast around those plugs with a torch,let the cast cool, or put it on your charcoal grill. Let it heat up and then naturally cool down. the plugs should screw right out.
CENTAUR
10-17-2007 12:52:12
Are they made to come out?You can clean by using high volume and high pressure after running some carburetor cleaner through and blowing out before it gets a chance to dry. CENTAUR
CENTAUR
10-17-2007 12:51:33
