Tractor Talk Discussion Forum
OT/ Update, New idea 324 corn picker pictures
KYfarm
10-17-2007 16:52:57
Okay, the other 3 bolts came right out of the gearbox so that was not a problem getting off. After looking at the mounting plate I realized that it had broken welds but could be pulled back in place with clamps
this is what it looked like after gearbox removed
third party image
then this is what it looked like with the clamps on it and the broken welds shined up with a wire brush
third party image
then after a day of welding, the mounting plate was an easy weld, the vertical brace which had been previously welded too cold was covered with weld boogers and had about a 1/4" gap to fill was a different story but it finally came out to look like this, one both sides
third party image
so now I'm ready to extract the one broken bolt and put it back together.
Thanks for all the advice yesterday
bradk
10-17-2007 19:07:20
 Re: OT/ Update, New idea 324 corn picker pictures in reply to KYfarm, 10-17-2007 16:52:57
Hows about another couple pics of the whole machine? Love those NI pickers.
KYfarm
10-18-2007 04:50:25
 Re: OT/ Update, New idea 324 corn picker pictures in reply to bradk, 10-17-2007 19:07:20
Okay, it is a picker and a sheller
this one from inside the tractor
third party image
and this one all hooked-up and ready to pick, but broken, quite common
third party image
Walt Davies
10-17-2007 17:06:44
I see that you have two nice beads down each side of the weld now to finish it add a third bead right down the center between each of the other two. That will greatly strengthen your weld. walt
super99
10-17-2007 17:50:08
 Re: OT/ Update, New idea 324 corn picker pictures in reply to Walt Davies, 10-17-2007 17:06:44
I agree with Walt, I was told years ago that several small overlapping beads were stronger than 1 large bead. Chris
