Tractor Talk Discussion Forum
OT: Ranger Speedometer Correction
supergrumpy
10-17-2007 17:33:18
picked up some very nice used tires and rims, tires are bigger and I know I will be traveling faster than the speedometer is now indicating
Is there a way to estimate how fast I need to keep speedo to travel at 55mph, my last resort is pacing a known accurate vehicle
FACTS:
2003 Ranger, V-6 automatic
original tires - 225/70-15
new tires - 235/75-15
rear end gears unknown
supergrumpy
10-18-2007 06:19:01
 Re: OT: Ranger Speedometer Correction in reply to supergrumpy, 10-17-2007 17:33:18
HEY, the police have that speed checker set up somewhere around here almost every day
thanks for the ideas
john *.?-!.* cub owner
10-17-2007 19:41:17
 Re: OT: Ranger Speedometer Correction in reply to 495man, 10-17-2007 17:33:18
it will cost you a few dollars, but since your odometer is electronic, a dealer can easily set it for you.
RobMD
10-17-2007 19:34:02
supergrumpy:
Ironically enough, i've been using this today to figure out my Jeep speedometer.
You just enter your information and see what speed you're at.
Walt Davies
10-17-2007 18:35:31
If your state has those mile markers along the road like we do in Oregon you can go 60 MPH and it should take 60 seconds or one minute to go 1 mile. Then see how far off you are and set your speed accordingly. Or go to a shop that does speedometers and they can put in a new gear to correct you speedometer. Walt
harry selleck
10-17-2007 17:58:28
Borrow someones GPS unit it will tell you exactly how fast you are going. I use one on my PU all the time they work well
rustyj
10-17-2007 17:56:51
Aww, just drop your speed on the speedometer by about 5 mph, and you should be ok. I installed 875x16.5 tires on the rear of my motor home, to carry the weight better than 800x16.5's. It made my speed register lower than the regular tires did, so i just drove 50mph,in a 55 mph zone, and it worked out right. We have those speed checkers that the cops set along the roads, to tell you how fast you are going, and thats a great way to check your speedometer for accuracy!
