Tractor Talk Discussion Forum
Fuel Filter
NW Brumley
10-22-2007 04:05:39
Does a 49 8N have a fuel filter like a car? If so, where is it at?
old
10-22-2007 08:47:43
 Re: Fuel Filter in reply to NW Brumley, 10-22-2007 04:05:39
Its jsut as Sound say unless of course some one removed one of more of them. I have seen a good number of them where one or more have been removed over the years and that will cause problem if some one did so
soundguy
10-22-2007 05:23:38
Had you actually posted this in one of the (2) ford forums you would likely have had 30 correct answers by now.
OEM, the N came with 3 filters.
A 'finger' shaped screen atop the tank tap, a round disc shaped screen in the glass bowl under the tap, and then another small screen attached to the fitting elbow at the carb.
Soundguy
CWL
10-22-2007 04:41:23
There should be a screen in the top of the fuel bowl if it has one. Also if memory serves me right the old fords had a screen in the fitting where the fuel comes out of the tank. It's been a while since I've messed with the fords though.
