Tractor Talk Discussion Forum
MF 35
JodyC
10-25-2007 13:44:58
Help Please
Have purchased a MF35 complete with front end loader. Purchased seperatly a 6' 3PH blade. Can't have the blade on the 3PH hitch when using the loader as blade falls to ground. Why won't the blade stay in the up position so I can use the loader. The loader stays up so I can use the blade.
Any help will be greatly appreciated.
Thanks
135 Fan
10-25-2007 18:38:55
 Re: MF 35 in reply to JodyC, 10-25-2007 13:44:58
If the loader runs off of the 3 pt. hydraulics the blade will creep down. I have the same problem on my 135. Most MF tractors 3 pt. arms creep down. Dave
Bob N.Y.
10-25-2007 15:29:43
In order to answer your question, it would be helpful to know how the loader hydraulics are plumbed into the tractor. Are you able to post a picture?
JodyC
10-25-2007 21:52:57
 Re: MF 35 in reply to Bob N.Y., 10-25-2007 15:29:43
Here's a picture of the diverter lever. I can take more photos if you let me know which ones you need.
Thanks for all the help.
Jody
Bob N.Y.
10-26-2007 16:35:52
 Re: MF 35 in reply to JodyC, 10-25-2007 21:52:57
You have a different arrangement than I have ever seen. I can tell you that there is no pressure on that port of the tractor unless the 3ph lever is higher than the corresponding position of the 3ph.
