Tractor Talk Discussion Forum
fiat 513R tractor
mokeydoke
10-26-2007 18:58:27
Can anyone help? I have a Fiat 513R tractor. and having trouble with the hydraulics. I can only get the pressure to 700psi and have a problem with the fluid aerating. Would apreciate any advice. Thanks so much Frank.
Wisconsin Cowman
10-26-2007 20:20:55
 Re: fiat 513R tractor in reply to mokeydoke, 10-26-2007 18:58:27
Your hydraulic pump could be getting weak or a relief valve is going bad.
Richard Honey
01-18-2008 15:15:17
 Re: fiat 513R tractor in reply to Wisconsin Cowman, 10-26-2007 20:20:55
I had the same problem, I replaced the pump etc with no improvement. I then removed the filter from the top of the 3 point linkage lift unit under the seat. The problem disapeared.
Try this. If it resolves the problem then find a replacement filter.
