Tractor Talk Discussion Forum
Farm Rated Hytran, Good or Bad?
48C-MAN
10-27-2007 10:54:50
Wondering if the Farm Rated (brand name) Hytran oil for Case IH is the correct oil to use in my touch conrtol unit on my Farmall C?
Don-Wi
10-27-2007 22:27:43
 Re: Farm Rated Hytran, Good or Bad? in reply to 48C-MAN, 10-27-2007 10:54:50
The stuff from Fleet Farm should be ok, espescially in a C - I'm assuming that's where you got it because I'm pretty sure that's the only place you can get it. When I need to do a 80/90 gear oil change I buy the Farm Rated stuff.
Donovan from Wisconsin
K.B.-826
10-27-2007 15:35:22
Will work fine in a C. Maybe a little lower quality oil than Hy-Tran, but it's better than the oils used when that tractor was new.
El Toro
10-27-2007 13:50:09
Hytran or HyGard should work well. Hal
