Tractor Talk Discussion Forum
Case 1370 3 Point problem
Jeremy Willmott
10-27-2007 19:10:53
I recently purchased a Case 1370. Everything works good on the tractor , but the three point. I tried it today and I cant get it to raise or lower. It does nothing at all. Anybody got suggestions, where to start?
ken in texas
10-29-2007 12:50:24
 Re: Case 1370 3 Point problem in reply to Jeremy Willmott, 10-27-2007 19:10:53
Onge had 1370 and had a control valve go bad.Same symptoms,and is mounted under the seat.It is high dollar.
omahagreg
10-27-2007 19:13:36
Jeremy, for starters, check your hydraulic fluid level. Greg
Jeremy Willmott
10-27-2007 19:23:34
 Re: Case 1370 3 Point problem in reply to omahagreg, 10-27-2007 19:13:36
How much should be in it, no dipstick. What type hydraulic fluid. Thanks
kyhayman
10-28-2007 07:06:45
 Re: Case 1370 3 Point problem in reply to Jeremy Willmott, 10-27-2007 19:23:34
If no dipstick, I'd get one and a set of filters ASAP. Go ahead and change the fluid and filters on it.
If everything works but the 3pt (hydraulic remotes, powershift, PTO) it sounds to me like the linkage is unhooked somewhere between the leaver and the internal parts of the control valve. Thats the first thing I would do is trace down the connections to make sure that the valve is opening.
If thats working then I would trace down the position control circuit. If the valve is open for aux or external power beyond it may have your 3pt shut off. Seems I recall there is a setting for that somewhere but I dont remember how to do it.
chess
10-28-2007 08:00:31
 Re: Case 1370 3 Point problem in reply to kyhayman, 10-28-2007 07:06:45
Good advise also he can see parts list on case web site.Dipstick is at right rearof tractor an part no is a153269. It is fillcap -breather- dipstick combination.Also tractor with that amount of age might have stiff controls so good shot of wd40 oh leaver pivot pins would be good idea.
Eric in IL
10-28-2007 09:20:41
 Re: Case 1370 3 Point problem in reply to chess, 10-28-2007 08:00:31
I'm not sure a dipstick was used on any of the 1370's. The ones I have seen use two sight bulbs which are located on the right side of the tractor, just in front of the rear axle. I use HY-TRAN oil from Case-IH dealer.
