Tractor Talk Discussion Forum
year-a-round cab
djm75
10-29-2007 03:23:06
I have a oliver 1650 with a yeararound cab and can"t get heat out of the heater. I don"t think the water is circulating thru it I have reversed the hoses and tried to bleed air and no luck. Any advice?
Thanks Don
msb
10-29-2007 06:58:23
 Re: year-a-round cab in reply to djm75, 10-29-2007 03:23:06
A very common occurence. Air lock. Remove the return hose and run the engine until coolant bleeds through.
Rick Kr
10-29-2007 06:45:59
Don,
Had the same problem last winter on a new to me AC7000. Checked the obvious and all the other things.
When I lifted the roof off the cab, the last person to put it together pinched the heater hose flat between the roof and the support.
Good luck,
Rick
Leland
10-29-2007 05:44:46
is there shut off valves not opened ??
Joe(TX)
10-29-2007 05:34:13
Is your thermostat good. The heater won't work very well with a thermostat stuck open or missing.
davediehl@hotmail.com
10-29-2007 03:44:43
Plugged heater core. Try attaching a garden hose to one side of the line going to the cab with the other disconnected from the engine. With low pressure, see if you get anything out of the other side. It might be time to flush the entire system.
djm75
10-29-2007 04:08:52
 Re: year-a-round cab in reply to davediehl@hotmail.com, 10-29-2007 03:44:43
I forgot to put that up its not plugged I checked before I ever hooked it up. thanks anyway
VPC1
10-29-2007 04:24:56
 Re: year-a-round cab in reply to djm75, 10-29-2007 04:08:52
Sounds like air lock to me. I would unhook the return line at the engine and run the tractor and let it push the air through the line. I've have had this problem before. Very common with the core being high above the water pump.
