Tractor Talk Discussion Forum
case 210b
P.Mac.
10-29-2007 18:34:25
My neighbour down the road has a 1959 case 210b with clutch problems.When he split it he found the throwout bearing collar had been spinning & the return spring piled up. He replaced the collar & spring put it together the way he took it apart & it made noises when he fired it up. Split it again found the samething. The collar has a tang on it & its a single disk clutch.Does anybody know which way the bearing goes? Bearing towards the fingers or the fork?
JRT
10-29-2007 20:42:11
 Re: case 210b in reply to P.Mac., 10-29-2007 18:34:25
The throughout bearing should have a little peg like petrusion sticking out of one side. If I remember correctly, that goes toward the clutch plate. I will try to remember to look at a picture tomorrow. I do know that if the beaing is backwards, it will cause the spring to jam up.
