Tractor Talk Discussion Forum
live hydraulics
Jim W.
10-30-2007 08:54:31
Without wanting to cause too much fuss, I was wondering if someone could give us a short tutorial on live hydraulics, what's good, what's bad, what generally get the job done, etc. We just bought a JD 4020 (has 2 remotes), and the hydraulics seem to leak a little (lift action is slow some, but full for power), but I am unknowledgeable about the "live" aspect. Thanks in advance for your time and consideration! Also, what about hdraulic fluid: is it all generic, or is it like car oil, you shouldn't switch brands? What's a good trade name here? When should you change it out? Other maintenance things we ought to do??
Jim W.
10-31-2007 07:31:54
 Re: live hydraulics in reply to Jim W., 10-30-2007 08:54:31
Thanks, gents! I am some clearer now on the topic. Have an operator's manual on the way. I'm looking out my window now at my "new" 4020, and am awed by some of the commentary I have picked up on here and over at Homesteading Today. I feller's got to have a lucky stroke every once and a while, and I may have had one here. I guess that remains to be seen. My next challenge will be to convert from this curved drawbar to a 3 point hitch. Word has it here in CO that that can be done for around $600. I'm not quite clear on that yet, but have noticed not too much info on the internet yet about that. Ideas??
paul
10-30-2007 19:37:16
You will likely have live hydraulics on that tractor. It means you can run the hydraulics if you do (or do not) have the clutch pushed in.
The first tractors drove everything from the rear end, after the clutch. This meant if you pushed in the clutch, the hyd pump would stop. They quickly realized this wasn't good, & drove the hyd pumps from a shaft in front of the clutch.
A related issue is live pto - same concept, but it took longer for tractors to get live pto. Was harder to get a live shaft to the back of the tractor....
As someone said, open center vs closed center may be an issue that comes up. JD liked to use closed center, not sure if they did on your model. It affects the types of hyd controls you can add to your tractor. Open center flows oil all the time, unless you move a lever & block the flow, diverting the oil to move your cylinder. Closed center has constant pressure, but only flows oil when it is needed by opening a lever.
Oil - your manual will list a specification that the oil has to meet. You have 3 options; JD brand oil which is more spendy, but some feel they get a better oil going with the OEM; an oil from a fleet & farm supply store that is designed for JD specs; or the same source of oil that is called 'universal' oil and lists in fine print many brands of oil that it is cvompatable with.
Since I have 3-4 brands of tractors & combine, I tend yo get the universal oil that is compatable with many things.
There is universal hydraulic oil, and there is universal tans/hydraulic oil. Big difference in them, many tractors use the rear end gear oil for the hyd sump, and the oil _must_ be good enough to lube those rear end gears. I try to always get the better grade trans/hyd oil so I don't goof & put the straight hyd oil in a gearcase.....
So, you can go to JD for oil, or you can shop at any farm supply store and get a compatable trans/hyd oil.
--->Paul
Mathias NY
10-30-2007 09:55:44
Live simply means that they work any time the engine is running.
Open-center vs closed-center is another question you may come across soon. I don't know which system your tractor has. Open-center means that the hydraulic pump will always pump the same amount of volume (gpm) regardless of how much demand there is. Closed-center is (in my impression) a better design. This setup only pumps as much oil as the system needs to maintain pressure. So if you are not using any hydraulics, the system will not be moving any oil, this saves on horsepower, fuel, and reduces puts less heat into the hydraulic oil. Sadly most manufacturors have gotten away from this type of system. As far as operating equipment with remotes, most people won't notice a difference between the two types of pumps.
There are generic hydraulic fluids out there, however they are not all the same grade of fluid. I would look up what Deere calls for on your 4020, probably their Hy-Gard brand fluid. Once you know the specs for the fluid you could cross reference it to a generic type.
buickanddeere
10-30-2007 18:11:42
 Re: live hydraulics in reply to Mathias NY, 10-30-2007 09:55:44
Mother Deere used live hydraulics on all the 20 series Waterloo tractors and most of the utility series. And closed on all of the 30 through 60 series. Wet clutch compatible oil must be used or the brake & pto linings will end up in the bottom of the trans sump.
mattd
10-30-2007 18:31:39
 Re: live hydraulics in reply to buickanddeere, 10-30-2007 18:11:42
deere has used closed center hyd systems starting with the 10 series with pressure compensated pumps. the same system was used until the 60 series the pump was just bigger. modern tractors are still closed center but the pumps are pressure and flow compensated.
buickanddeere
10-30-2007 19:53:16
 Re: live hydraulics in reply to mattd, 10-30-2007 18:31:39
True about the Waterloo 10 series also being closed center, I missed being clear about that. The 1010, 2010 & I think the 820 utility tractors were open center. Some of the new tractors built by Deere since 1990 after the 60 series have been open center.
JMS/.MN
10-30-2007 09:31:35
'Live' simply means that hydraulic power is available whenever the engine is running, as opposed to hydraulic systems that stop when using a clutch to start or stop tractor motion. Get the operator manual for the tractor for advice on oils, intervals, etc. Also explains how to set the lever on the remote for fast/slow lifting.
