Tractor Talk Discussion Forum
Polarize Generator
Don E. Foster
10-31-2007 10:22:19
Have Ford 2000, 3 cyl. gas. New voltage reg. 12 v. +ground. How do I polarize the gen? You've told me before but I sure sometimes forget (86 years old)....
ILikeCase
11-01-2007 00:49:17
 Re: Polarize Generator in reply to Don E. Foster, 10-31-2007 10:22:19
Bolt the generator up but don't install the belt or any wiring. Run a jumper from Battery + to the + on the generator. It will spin like a motor. Now go ahead and finish hooking everything up and go to work.
John T
10-31-2007 14:39:40
To polarize the genny, you can momentarily temporarily flash/jump/spark a wire from BAT on the VR over to its GEN/ARM terminal and you ought to get a small spark. Same things accomplished if you were to flash/jump/spark a wire from BAT on the VR (or any hot ungrounded battery voltage source for that matter) direct to the gennys ARM post. Do it BEFORE start up. You can first dead ground the Gennys FLD post to insure a good ground but if alls correct n the VR is good n grounded it should already have a ground via the VR. Dont be jumping to the VR or Gennys FLD post, jump to the ARM/GEN post per the above.
John T
JMS/.MN
10-31-2007 12:01:30
I know that there is a real defeniton- copied it before....but Dad always said- take a jumper wire, and touch it to any two contacts that make a spark, and it is polarized.
