Tractor Talk Discussion Forum
Re: curved drawbar on JD 4020
toolz
10-31-2007 15:52:46
The JD top links are expensive because that's all that will fit. The generic aftermarket links with ball rod-ends will not pin to the tractor bracket since there is not enough clearance. You either have to get original JD, or JD replica, both are expensive. Should be able to find JD for about $100.
