Tractor Talk Discussion Forum
Re: D-17 Stuck
old
11-06-2007 07:15:45
Starter maybe locked up on the ring gear. By the way you should NEVER try to pull a tractor to get it to turn over or you can/will brake parts in the engine and or tranny. I would pull the starter off and then see if the engine will turn. You can turn the engine with the fan belt or a pry bar at the flywheel. Pull the plugs out because that will make it turn easier. Also by pulling the starter you can get a look at the clutch
njm
11-06-2007 08:02:01
 Re: D-17 Stuck in reply to old, 11-06-2007 07:15:45
Thanks .... Forgive Me :)
